Replacing Cisco Switch WS-C3650-24PS-L
Hi Cisco Community,
I'm using Cisco Switch WS-C3650-24PS-L, but it needs to be replaced because of something is broken.
Unfortunately, it is really hard to find the WS-C3650-24PS-L in Indonesian Market.
Any recommended switch that can replace WS-C3650-24PS-L? Because, our understanding are the switch cannot be connected if we replaced with a different type.
Thank you.
Awaiting feedback.
Leo Laohoo
3650 switches can still be RMA-ed.
Thanks for the information,
But if in a urgent condition, can we replace it by other c3650-24ps type or any switches?
Thank you.
Is the faulty unit in a stack?  Yes, it can be replaced quickly as long as the following guidelines are followed:
  • Replacement unit must be loaded with the exact same firmware
  • The stack's firmware must either be in Install or Bundle mode
  • IMPORTANT:  Power down the replacement unit, connect the stacking cable, power up the unit.  Do connect the replacement unit to the stacking cable while powered.
thank you sir, i will refer this method to the team.
good afternoon.
