Requierment to do ccnp
Arijit Das
Hello guys,
I have one question. Little off the track.
I have done ccna and one paper of ccnp (642-812-Switching).
Now my question is if I do Route (642-902) and TSHOOT will the CCNPcertification be done or I have to sit for the Switch(642-813) again.
I am really confused with this. Please help.
Arijit
7 Replies 7
burleyman
Level 8
Level 8
When did you pass your CCNA and Switch exams?
Mike
fsebera
Level 4
Level 4
Depends on when you took the switching exam.
Each exam has a time limit and expiration date.
I have passed switching (BCMSN) on August 2010.
Is it OK.
Please reply.
Arijit
Sandeep Choudhary
To do a CCNP , you have to be clear in all three paper(Route, Switching, TSHOOT).
If you have done with switching then go for ROUTE and TSHOOT.(Just check the time period for valitidy of certificatios.)
Actually I have done ccnp switching (BCMSN) in 2010.
is it ok.
Arijit
if i read this and use this tool, then you only need ROUTE and TSHOOT. (I checked the
http://www.cisco.com/web/learning/le3/le2/le37/le10/ccnp_exam_combo_tool.html
Thanks a lot Ton.
I have ticked the route, Tshoot and bcmsn boxes together and it shows that CCNP achived.
Thanks a lot again.
Arijit
