Reset module command in cisco -6509
saurabhba
Community Member
Hi Team,
We need to reset/reload one of the module of our core switch i.e.WS-C6509-E. Moreover, we have tried the command reset 4 (module no.) but it's not working. Please provide us the command to reset the module.
Giuseppe Larosa
Hello Saurabh,
it should be
hw-module module 4 reset
given in SWitch# privileged mode
Switch#hw-module module 4 ?
boot Specify boot options for the module through Power Management Bus control register
reset Reset specified component
simulate Simulate options for the module
some specific service modules like CSM or other can require different approach
This is good for normal linecards
Hope to help
Giuseppe
Hi Giuseppe,
I have tried reseting one of the module of WS-C6509-E. I could not complete the process because of below error.
% module 3 is operationally Off (Module Reset due to exception or user request)
Go to config mode and enter "power enable module {Module Number}" and exit config mode.
Before the system has time to detect the error and turn power back off, you will be able to do the reset.  Most likely it will solve nothing, but you can still do it.
