Reset Password and Retrieve Configuration on Switch 2950 and 3560
Tang-Suan Tan
Hi all:
I need help how to recover password and retrive configuration on Cisco switch 2950 and 3560.
I know the way to press and hold the mode button and then plug in the power cord can reset the switch to factory default but it will reset everything to nothing. As such, it is not what I want and I want to keep the configuration file and able to use the configuration on the switch.
Anybody can propose the link or solution, please help as soon as possible. Many thanks!
regards,
tangsuan
Reza Sharifi
Reza Sharifi
If you follow this link step-by-step, you are not going to loose your configuration.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.1_19_ea1/configuration/guide/swtrbl.html#1021182
Hi Reza:
Thanks to your reply!
I follow the step by your link and the problem is resolved. Thanks to your help!
warmest regards,
tangsuan
