Reset password on a Switch 2950 catalyst
yuzeka
Hi everyone,
In order to create an infrastructure for an exam, we retrieved several Cisco switches that had been used before.We have reset the passwords of many of them, but we encounter a problem with the switch 2950 catalyst. We can't reset it with the normal procedure because the "mode" button is broken
Does anyone have a solution for this problem?
Thank you in advance and please forgive my syntax mistakes as English is not my native language.
Good day to all
balaji.bandi
we always follow the same steps : (only place it will not work if any one configured disabled service password-recovery)
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/12040-pswdrec-2900xl.html
if service password-recovery disabled , then you need to with ROMMON process with console.
BB
balaji.bandi
BB
yuzeka
Hi balaji.bandi.
Thanks you for your answer, i will try this as soon as possible.
Bye bye
