Reset Password on switch
cknox1
Level 2
Level 2
I remember that breaking passwords on Cisco router is by changing config reg in Rommon mode - Is this the same process for Cisco switches? Can someone please help
Also, when doing password recovery on switch, can you keep the exiting configuration?
Switching
Help will be great.
5 Replies 5
balaji.bandi
Depends on the model, what access level you have to reset, if you lost all, then reset will erase all the information to factory default.
here is the reset to factory :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2900-xl-series-switches/24328-156.html
BB
Leo Laohoo
That depends if "no service password-recovery" is in the config or not.  If this command is in the startup-config then when doing the password-recovery procedure the configuration is erased.
Hi Thank you for your reply,
The model is 2960x, does this have it on by default?
Follow the steps in this link.
https://www.rogerperkin.co.uk/cisco/password-recovery/password-recovery-cisco-2960x/
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future.
Best regards,
Lucas Freitas
No by default not configured and its not standard.
if the user configured it will be lost - hope this make sense ?
BB
