Reset VTP revision number
Andy White
Level 3
Level 3
I have 5 switches in a VTP domain, one switch is the server and the reset are clients.  How can I reset the revision number back to zero?  If I change the domain to something else on the server or set it to transparent it goes to zero, but it I set it back to the server and the original domain name it goes back to the old revision number.  I guess the clients are updating the revision number?
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Yes, correct.  Servers and clients "share" the VLAN database.  The real difference between "servers" and "clients" is whether you can configure VLAN changes on the device.
Set all switches to transparent, and then set them all back to their previous server or client mode.
PS:
Changing the domain name, as noted by Reza, on all switches and then back should do the trick too.
Reza Sharifi
Configuration Revision Number
The configuration revision number is a 32-bit number that indicates the       level of revision for a VTP packet. Each VTP device tracks the VTP       configuration revision number that is assigned to it. Most of the VTP packets       contain the VTP configuration revision number of the sender.
This information is used in order to determine whether the received       information is more recent than the current version. Each time that you make a       VLAN change in a VTP device, the configuration revision is incremented by one. In order to reset the configuration revision of a switch, change the VTP domain       name, and then change the name back to the original name.
more info:
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_tech_note09186a0080094c52.shtml
Joseph W. Doherty
Disclaimer
Posting
PS:
Thanks, yeah I didn't realise you had to change it on all then back again.  Great to know.
shamax_1983
Level 3
Level 3
Just change the vtp mode to transparent and back to what ever the mode you want it to be.
Please rate this post if helpful.
