VLAN problem/missing ??
shahid_duet
Level 3
Level 3
I m using all cisco switch in my network. See my diagram.
My configurations are here:
Router : 3845
int F 0/0/1
ip add     192.168.0.252/24
int F 0/0/1.2
encaptulation dot1lQ 15
ip address 192.168.3.252/24
Core Switch 4507
interface GigabitEthernet3/1
switchport mode trunk
interface GigabitEthernet3/2
interface Vlan15
ip address 192.168.3.250 255.255.255.0
interface Vlan20
ip address 192.168.0.250 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.0.252
Assess Switch 2960
interface FastEthernet0/1
interface FastEthernet0/2
switchport access vlan 20
interface FastEthernet0/3
switchport access vlan 15
interface Vlan15
ip address 192.168.3.98 255.255.255.0
no ip route-cache
interface Vlan20
ip address 192.168.0.98 255.255.255.0
no ip route-cache
ip default-gateway 192.168.0.254
When i access my server( 192.168.10.10) from 192.168.0.14 its faster and ping latency always 1 ms.
When i access my server( 192.168.10.10) from 192.168.3.14 its lower and ping latency sometime 100,200,350,1,1,1, ms etc.
whats my mistake and how i access faster from 192.168.3.14.
Please help Me.
Shahid
kcnajaf
Level 11
Level 11
Hi Shahid,
For some reason the configuration you have provided above does not match with the diagram specifically for acces vlans and trunk ports.
Also it looks like you have ip address assigned to physical interface as well as subinterface? Can these IP's be assigned both to sub interface and encapsulate with correct vlan numbers (20 and 15)???
If i was you i will follow below steps to isolate the problem.
1) Verify if there is any errors on the port where 192.168.3.14 is connected.
2) If this port is configured with speed and duplex to autonegotiate, hardcore this manually both on switch end and on PC end as well.
3) Verify how the spanning tree path for VLAN 15 and comapre it with VLAN 20.
4) Try pinging between the PC's to verify if you see the performance difference like what you see to Server.
5) Verify if there are any errors on the trunk links from access switch all the way till router.
Hope this helps.
Please rate when applicable or helpful !!!
8 Replies 8
kcnajaf
Level 11
Level 11
Hi Shahid,
Hope this helps.
Hi Najaf
What is the mismatch ??
pls tell me. i am finding that
So you want me to tell this rather than you finding it yourself 🙂
Fair enough here it goes.
Accoring the above configuration you have shared for the access switch 2960.
Fas 0/1 - Trunk
Fas 0/2 - Vlan 20
Fas 0/3 - Vlan 15
But in your diagram
Fas 0/1 - Vlan 20
Fas 0/2 - Vlan 15
Fas 0/3 - Vlan 20
Fas 0/4 - Vlan 15
Hope now you get that.
Najaf
hi najaf
yes i have mismatch.Here configuration is corrct and mistake at diagram.
I did HSRP on router F 0/0/1 like
standby 4 priority 140
standby 4 preempt
standby 4 track GigabitEthernet0/1
If i want to change config f0/0/1 to f0/0/1.1 it says
%Must use unique HSRP group number for each logical interface
that is a member of the same physical interface.
But inf f0/0/1.2 dont have any HSRP.
Firstly
How i configure f0/0/1.1 with
standby 4 preempt
secondly, i am not clear ur suggestion # 3. pls descrive me.
Thanking YOu
shahid
Mr. najaf
Yes, i got problem. when i changed f 0/0/1.2 configuration to another physical interface  its working and have no problem.
Is it possible to do HSRP at only one sub-interface ????
shahid
Hi Shahid,
Glad to hear that your issue is resolved.
Do you have dual (pair of ) Core Switches?
There is no fun in running HSRP only on one interface. The purpose of HSRP is to provide first hope resiliency. If you configure it only on one device and if this goes down there is no fall back. So HSRP to work you need to configure them on two interface of seperate devices.
Hope you are getting my point.
Najaf
Najaf
I have 2 switch and 2 router.
Now my situation stands i have to do HSRP between prinary router sub-interface and secondary router physical interface. prinary router another sub-interface need not do HSRP.
is it possible to do at sub-interface ?????
shahid
Hi Shahid,
HSRP will work on Sub interface, as long as you have L2 path between the physical interface and subinterface. Still I was not able to figure out a practical schnerio why you would want to use this way 🙂
Anyway you can give a try and it should work.
Najaf
