Rest Admin Password for Catalyst 4507r switch
Ruba
Dears,
I have Cisco 4507r switch, and i cannot login to admin because admin password is lost.
I tried to enter the rommon mode as stated in the link below but after step 3 the supervisor module go to standby mode and i was not enable to proceed:
Step 1: Power cycle the device.
Step 2: Press Ctrl-C within 5 seconds to prevent autoboot.
Step 3:
Rommon 1 > set
Rommon 1 > confreg
Configuration Summary :
 => load ROM after netboot fails
 => console baud: 9600
 => autoboot from: commands specified in 'BOOT' environment variable
 do you wish to change the configuration? y/n  [n]:  y
 enable  "diagnostic mode"? y/n  [n]:  n
 enable  "use net in IP bcast address"? y/n  [n]:  n
 disable "load ROM after netboot fails"? y/n  [n]:  n
 enable  "use all zero broadcast"? y/n  [n]:  n
 enable  "break/abort has effect"? y/n  [n]:  n
 enable  "ignore system config info"? y/n  [n]:  y
 change console baud rate? y/n  [n]:  n
 change the boot characteristics? y/n  [n]:  n
 => ignore system config info
 do you wish to save this configuration? y/n  [n]:  y
 You must reset or power cycle for new configuration to take effect
Then I reset then I got the standby mode.
Password Recovery Procedure for Catalyst 4500/4000 Supervisor Engine II+/II+TS/II+10GE/III/IV/V/V 10GE Module and Catalyst 4900 Switches that Run Cisco IOS Software - Cisco
How can I get out of standby mode to continue or how can I rest the password.
Thank you.
marce1000
 - If it has  dual supervisors installed , can you proceed on the active supervisor , or else post screenshot (?)
 M.
balaji.bandi
If you have dual Sup cards foillow below thread : ( you need to do this maintenance window, when you reset primary it fail over to other, so you sup card you tried become standby)
https://community.cisco.com/t5/switching/password-recovery-on-dual-sup-4510r/td-p/1447482
BB
