web interface on switch 2960
nidonido2013
Hello everybody,
I made the update of C2960 24 port and 8 port model switches with the .bin file
I noticed on the internet that this installation does not include the web interface,
it is necessary to have the .tar file to obtain this web interface.
Is it possible to add the web package from now on without completely updating the switch?
Thanks for your help
Bests Regards
Dorian
6 Replies 6
balaji.bandi
.bin do not have GUI config facility.
- yes you need .tar file upgrade to get GUI config
- No not possible ? not sure what webpage here, you looking GUI config right ?
BB
Martin L
Yes, you will need a .tar file (not bin file);  Get tar and open it with 7zip or WinRar program to see If you have GUI folder or html, then copy that to flash.  So, I think you could add it GUI or html folder manually; I did it some time ago on my voice router. see If you unzip tar file and have GUI folder or html, then copy that to flash.
Regards, ML
**Please Rate All Helpful Responses **
nidonido2013
Hello Thank you very much for your quick answers, I will try to put the html file manually in the flash of
the switch and see what it gives. I'll keep you informed.
Thanks you
Bests Regards
Dorian
Do you mean manually create the folder and copy HTML files, I never tried and that is not the approach right i guess.
BB
nidonido2013
I pushed the .tar firmware, so the file is now with the html package. However, the web page is still in 401 error, do you have any idea? Here is the configuration:
VASW104#dir flash:
Directory of flash:/
503 drwx 512 Nov 23 2021 09:04:56 +00:00 c2960x-universalk9-mz.152-7.E4
3 -rwx 34 Oct 14 2021 13:28:16 +00:00 pnp-tech-time
4 -rwx 139479 Oct 14 2021 13:28:17 +00:00 pnp-tech-discovery-summary
5 -rwx 26767360 Oct 14 2021 13:32:26 +00:00 c2960x-universalk9-mz.152-7.E4.bin
7 drwx 512 Jan 29 2021 19:52:13 +00:00 c2960x-universalk9-mz.152-7.E2
2 drwx 512 Nov 23 2021 09:04:57 +00:00 dc_profile_dir
500 -rwx 3828 Nov 23 2021 09:04:54 +00:00 private-config.text
501 -rwx 856 Oct 27 2021 12:17:46 +00:00 vlan.dat
502 -rwx 3096 Nov 23 2021 09:04:56 +00:00 multiple-fs
996 -rwx 4091 Nov 23 2021 09:04:54 +00:00 config.text
122185728 bytes total (11804672 bytes free)
VASW104#dir flash:c2960x-universalk9-mz.152-7.E4
Directory of flash:/c2960x-universalk9-mz.152-7.E4/
504 drwx 1536 Nov 23 2021 08:16:21 +00:00 html
993 -rwx 26767360 Nov 23 2021 08:27:26 +00:00 c2960x-universalk9-mz.152-7.E4.bin
994 -rwx 688 Nov 23 2021 09:04:52 +00:00 info
VASW104#show boot
BOOT path-list : flash:/c2960x-universalk9-mz.152-7.E4/c2960x-universalk9-mz.152-7.E4.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : yes
Manual Boot : no
Allow Dev Key : yes
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
Boot optimization : disabled
NVRAM/Config file
buffer size: 524288
Timeout for Config
Download: 0 seconds
Config Download
via DHCP: disabled (next boot: disabled)
#ip http server
#ip http banner
#ip http authentication local
#ip http secure-server
#username test privilege 15 password XXXX
 Bests Regards
Dorian
I specify that I made the update via the command:
Archive download /overwrite ......
