Restconfig yang model
mohamedshahid
Community Member
I was trying to access the cisco switch of NX-OS 9500v through restAPI and I see that only System API(restconf/data/Cisco-NX-OS-device:System/) is accessible and then other,
I have  a query , where can we find the restconf API documentation and data models, we want the info on the switch like type, interfaces, Vlans, and how to create a Vlans in that switch, pls help which APIs would be helpful in providing these solutions?
Shahid
10 Replies 10
balaji.bandi
check restconf config example :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/progammability/guide/b-cisco-nexus-9000-series-nx-os-programmability-guide-93x/b-cisco-nexus-9000-series-nx-os-programmability-guide-93x_chapter_011100.html
here is the API reference :
https://developer.cisco.com/site/cisco-nexus-nx-api-references/
Note : most of the document was Physical Kit, Virtual there may be some limitration check the document before you deploying it.
BB
mohamedshahid
Community Member
I found a few restconfig APIs with the yang System model "https://<nxos-switchIP>/restconf/data/Cisco-NX-OS-device:System/"  --> this gives output.
But when I used openconfig models for example the below one https://nxos1/restconf/data/openconfig-interfaces:interfaces
it always gives "400 Bad request", any idea why, I found the similar issue reported in github too: https://github.com/YangModels/yang/issues/270 but no resolution for that still....
Shahid
post the full XML request you are using. Which NX-OS version are you running on the 9500v ?
mohamedshahid
Community Member
is the version Nexus 9000v
I am accessing the get API's, not doing any POST operation
 GET https://<switch-ip>/restconf/data/openconfig-interfaces:interfaces?content=config
Can you post show run output here
BB
mohamedshahid
Community Member
Hi @balaji.bandi ,
I have attached the output
The response what I get is status code: 400 with body {}
Shahid
requested the config -  show run
BB
mohamedshahid
Community Member
Have attached the output in the file
Regards..
mohamedshahid
Community Member
@balaji.bandi ,
Can you please share any updates on the issue?
Shahid
i have not got chance to test, this in my Lab, i will revert back when i get a chance to test it.
BB
