Restricting Inter-VLAN routing
Adnan Fakruddin
I'm looking to restrict Inter-VLAN routing through L3 switch (cisco 6500) and wanted to know best possible way to do it.
I used VACL and achieved success to some extent, but my config is making clients take up to 5-6 mins to authenticate IP address from the DNS (bootps).
My VACL config was as follows:
Subnet to restrict is 10.100.15.0 (VLAN 15)
STEP 1: Created extended ACL to allow bootpc/bootps through DNS
ip access-list extended EACL_DNS
permit udp any eq bootps any
permit udp any eq bootpc any
STEP 2: Created standard ACLs to allow only relevant subnet, server VLANs & some IPs from other subnets for printers/scanners etc.
ip access-list standard SACL_VLAN_15
permit 10.100.15.0 0.0.0.255 (the subnet I'm restricting)
permit 10.100.50.0 0.0.0.255 (server VLANs)
permit 10.100.25.45 0.0.0.0 (printer in another VLAN which has to have access in VLAN 15)
STEP 3: Created VLAN access list
vlan access-map VACL_15 10
match ip address EACL_DNS
action forward
vlan access-map VACL_15 20
match ip address SACL_15
action forward
STEP 4: Applying VLAN Access list on VLAN 15
vlan filter VACL_15 vlan-list 15
Though the above works, below is noted:
1. I'm still able to PING 10.100.15.2 (the switch virtual interface) from outside the subnet, which I don't intend to do so. Howeve all cients in the subnet have no connectivity from outside the VLAN 15.
2. As mentioned its taking quiet some time to negotiate with the DNS server at system boot time.
I'm sure there could be other ways of doing it, I'm looking for some tunning in above or best possible way to achieve it without putting in too much load on the core. I've approx. 15 VLANs to segregate and restrict Inter-VLAN routing.
Thank you.
Adnan
blau grana
Level 7
Level 7
Hello Adnan,
VACLs should be used for restricting communication inside same broadcast domain (same subnet).
Did you try implement ACLs on L3 LAN interfaces?
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Jan Rolny
Level 3
Level 3
Hi Adnan,
you can use Private VLAN configuration. You can isolate communication with it.
Best Regards,
Jan
Hello Jan,
With private VLANs you will not restrict intervlan communication, just intravlan communication.
Best Regards
