RING TOPOLOGY - MIGRATION FROM OTHER VENDOR TO CISCO IE
vaguirre17
Hello world
we are planning a migration from a ring topology using hiper ring to cisco IE switches but don't know how minimize the downtime in the different locations.
balaji.bandi
When you Migrating from one vendor to other vendor i am sure you will have small downtime need to be agreed when you move the Physical connection end device to new IE Switch.
I prefer to do this way, Build new IE Ring and  in the Main Location connect one of the IE Switch to Other Ring network to enable connection between Old ring network to new Ring network - start Migrating the Devices in each Location - start with less impacted device and Monitor the network stability before you Migrate rest of the devices.
Hope this helps you.
BB
