10-01-2013 06:59 AM - edited 03-07-2019 03:46 PM
Hey guys,
Let's say I have one router, that has a BGP peer (which is for MPLS L3 VPN) and running RIP as well, and only advertising the LAN network.
Now here is the following configuration.
Router
router rip
version 2
no auto
redistribute connected
redistribute static
network 2.0.0.0 (Lan interface is 2.2.2.0/29) In this example
redistribute bgp metric 3
router bgp 64518
redistribute rip
Now, I would assume, that sence, during redistribution, the router will only redistribute from the routing table and not the "topology database",
that, when I redistribute rip into bgp, it's going to take all the routes in the routing table, that are marked (R). Sense, the connected and static routes
will have an Administrative Distance of 1 and 0, they will beat out the RIP routes and will not be redistributed into BGP.
I'm just making sure my assumption is correct?
Solved! Go to Solution.
10-01-2013 07:12 AM
Yes a router can only redistribute what is in the Routing table so your Rip installed routes will get redistributed but not your connected and static entries which will be advertised by RIP and installed as such on RIP peers.
Alain
10-01-2013 07:12 AM
Alain
10-01-2013 07:36 AM
Thanks Cadet, that's kinda what I thought. Sometimes it's nice to have a 2nd opionion every now and then.
