10-01-2013 06:25 AM - edited 03-07-2019 03:46 PM
Can I use SFP (1G) modules in the SFP+ uplink slots of the switch. The idea is to use today 1G uplinks but keep it future proofed for 10G migration later on.
Jan
Solved! Go to Solution.
10-01-2013 08:09 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
From 2960X Q&A:
Q. Does the 10 Gigabit uplink upgrade require a separate module?
A. No. The SFP+ and SFP slots are built in.
Q. Can the 10 Gigabit SFP+ slots on the Cisco Catalyst 2960-X model support 1 Gigabit SFP modules?
A. Yes. The Cisco Catalyst 2960-S models that support 10 Gigabit SFP+ modules can also support SFP modules that operates at 1 Gigabit.
Note: I believe the last answer has a typo - i.e. was copied from the 2960-S Q&A which says slot supports both.
10-01-2013 06:47 AM
I don't believe the uplink for the 2960X series switches are modular. So, if your switch support SFP+ than you can only insert SFP+ and not both.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12995/data_sheet_c78-728232.html
10-01-2013 08:09 AM
Disclaimer
Posting
From 2960X Q&A:
