RIP Query
wasiimcisco
I have three Routers connected in the LAN.
R1-------------->R2------------------>R3
RIP              Static               RIP
I wanted to exchange the RIP Routes between R1 and R3 but I cant run the RIP or any other protocol on R2.
I can only add the Static routes in R2.  My objective if I will advertise any route in R1 it should goes to
R3 via RIP update.
Please let me know how to achieve this.
Hello Wasiim,
you need to instruct routers to avoid to check RIP IP source:
>> RIP: ignored v2 update from bad source 155.1.13.5 on FastEthernet0/1/0
no validat-update-source
see
http://www.cisco.com/en/US/docs/ios/iproute_rip/command/reference/irr_rip.html#wp1012874
be aware that in real world no one will never do something like this
Hope to help
Giuseppe
8 Replies 8
   You can create a tunnel interface to connect between R1 and R3 and run RIP on the tunnel interface.
HTH,
Toshi
Thanks for the reply. But I discussed this with my Friend but he is saying there is another way to do this. Actually this is a lab setup and my friend has put this question how to achieve this RIP routing exchange between two routers when the middle router is only having static routes.
Any idea how to achieve this without making tunnel.
Shahzad Qadir
You will have to configure static route on R1 to reach R3 and vice versa. Once they have reachability they can share rip unicast updates without any problem, you will have to configure a neighbor statement on R1& R3 so they start sending unicast updates rather than default broadcast.
Thanks for the reply i tired the same but no luck
   5.5.5.5.5 and 6.6.6.6(----------R5--------------------------------------->R4<-------------------------------------------->R3-----) 3.3.3.3  & 1.1.1.1
                                        .5           155.1.13.x                  .4  .4            155.1.23.x               .3
ENOC-R3-HO#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/1/0          155.1.23.3      YES manual up                    up
Loopback0                  3.3.3.3         YES manual up                    up
Loopback1                  1.1.1.1         YES manual up                    up
ENOC-R3-HO#show run | b r r
router rip
version 2
network 1.0.0.0
network 3.0.0.0
network 155.1.0.0
neighbor 155.1.13.5
no auto-summary
ip forward-protocol nd
ip route 155.1.13.0 255.255.255.0 155.1.23.4
ENOC-R3-HO#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
ENOC-R4-HO       Fas 0/1/0          178         R S I     1841      Fas 0/1/0
ENOC-R3-HO#ping 155.1.13.5
Sending 5, 100-byte ICMP Echos to 155.1.13.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
*May 31 15:06:34.744: RIP: sending v2 update to 224.0.0.9 via FastEthernet0/1/0 (155.1.23.3)
*May 31 15:06:34.744: RIP: build update entries
*May 31 15:06:34.744:   1.1.1.1/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:06:34.744:   3.3.3.3/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:06:34.744:   155.1.23.0/24 via 0.0.0.0, metric 1, tag 0
*May 31 15:06:34.744: RIP: sending v2 update to 155.1.13.5 via FastEthernet0/1/0 (155.1.23.3)
R5#show ip int brief
Loopback0                  6.6.6.6         YES manual up                    up
Loopback1                  5.5.5.5         YES manual up                    up
Vlan1                      155.1.13.5      YES manual up                    up
R5#show run | b r r
router rip
version 2
network 5.0.0.0
network 6.0.0.0
neighbor 155.1.23.3
no auto-summary
ip route 155.1.23.0 255.255.255.0 155.1.13.4
ip http server
no ip http secure-server
control-plane
line con 0
R5#ping 155.1.23.3
Sending 5, 100-byte ICMP Echos to 155.1.23.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
*May 31 15:15:43.755: RIP: sending v2 update to 224.0.0.9 via Loopback1 (5.5.5.5)
*May 31 15:15:43.755: RIP: build update entries
*May 31 15:15:43.755:   5.5.5.5/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:15:43.755:   6.6.6.6/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:15:43.755: RIP: ignored v2 packet from 5.5.5.5 (sourced from one of our addresses)u all
ENOC-R4-HO#ping 155.1.23.3
ENOC-R4-HO#ping 155.1.13.5
ENOC-R4-HO#
ENOC-R4-HO#show ip int brief
FastEthernet0/1            155.1.13.4      YES manual up                    up
FastEthernet0/1/0          155.1.23.4      YES manual up                    up
Please let me know what I am missing
R3's config is fine. On router 5 you are missing network statement for 155.1.23.0
if look at debugs you will see r3 is sending updates to unicast address of R5 but R5 is still sending updates to 224.0.0.9
R5(config)#do sh run | b r r
router rip
version 2
network 5.0.0.0
network 6.0.0.0
network 155.1.0.0
neighbor 155.1.23.3
no auto-summary
May 31 15:56:09.370: RIP: ignored v2 update from bad source 155.1.23.3 on Vlan1
*May 31 15:56:10.434: RIP: sending v2 update to 224.0.0.9 via Loopback1 (5.5.5.5)
*May 31 15:56:10.434: RIP: build update entries
*May 31 15:56:10.434:   5.5.5.5/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:56:10.434:   6.6.6.6/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:56:10.434:   155.1.13.0/24 via 0.0.0.0, metric 1, tag 0
*May 31 15:56:10.434: RIP: ignored v2 packet from 5.5.5.5 (sourced from one of our addresses)
*May 31 15:56:14.946: RIP: sending v2 update to 224.0.0.9 via Vlan1 (155.1.13.5)
*May 31 15:56:14.946: RIP: build update entries
*May 31 15:56:14.946:   5.5.5.5/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:56:14.946:   6.6.6.6/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:56:14.946:   155.1.13.0/24 via 0.0.0.0, metric 1, tag 0
*May 31 15:56:14.946: RIP: sending v2 update to 155.1.23.3 via Vlan1 (155.1.13.5)
ENOC-R3-HO#sh run | b r r
router rip
version 2
network 1.0.0.0
network 3.0.0.0
network 155.1.0.0
neighbor 155.1.13.5
no auto-summary
ENOC-R3-HO#sh
*May 31 15:40:39.375: RIP: sending v2 update to 224.0.0.9 via Loopback1 (1.1.1.1)
*May 31 15:40:39.375: RIP: build update entries
*May 31 15:40:39.375:   3.3.3.3/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:40:39.375:   155.1.23.0/24 via 0.0.0.0, metric 1, tag 0
*May 31 15:40:39.375: RIP: ignored v2 packet from 1.1.1.1 (sourced from one of our addresses) ru
*May 31 15:40:40.543: RIP: sending v2 update to 224.0.0.9 via Loopback0 (3.3.3.3)
*May 31 15:40:40.543: RIP: build update entries
*May 31 15:40:40.543:   1.1.1.1/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:40:40.543:   3.3.3.3/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:40:40.543:   155.1.23.0/24 via 0.0.0.0, metric 1, tag 0
*May 31 15:40:40.543: RIP: ignored v2 packet from 3.3.3.3 (sourced from one of our addresses)
*May 31 15:40:42.707: RIP: sending v2 update to 224.0.0.9 via FastEthernet0/1/0 (155.1.23.3)
*May 31 15:40:42.707: RIP: build update entries
*May 31 15:40:42.707:   1.1.1.1/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:40:42.707:   3.3.3.3/32 via 0.0.0.0, metric 1, tag 0
*May 31 15:40:42.707:   155.1.23.0/24 via 0.0.0.0, metric 1, tag 0
*May 31 15:40:42.707: RIP: sending v2 update to 155.1.13.5 via FastEthernet0/1/0 (155.1.23.3)
*May 31 15:40:47.323: RIP: ignored v2 update from bad source 155.1.13.5 on FastEthernet0/1/0
Hello Wasiim,
see
Hope to help
Giuseppe
Thanks for the reply. I am able to receive RIP routes. This is only lab setup for our practice etc.
