RIP updates not getting from 1811 to 3750x
mike-elliott
I am trying to get a 1811 to update routes on a 3750x.  My static routes are being redistributed to the switch fine, however my connected networks are not
My router has Vlan with several subnets attached.
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$ES_LAN$$FW_INSIDE$
ip address xxx.xx.xx7.185 255.255.255.0 secondary
ip address 172.90.0.185 255.255.255.0 secondary
  ip address 172.99.0.1 255.255.255.0 secondary
ip address 10.170.10.254 255.255.255.0 secondary
ip address 10.173.10.254 255.255.255.0 secondary
ip address 10.162.10.254 255.255.255.0 secondary
ip address 172.21.10.1 255.255.252.0 secondary
ip address 172.21.40.1 255.255.255.0 secondary
ip address 172.30.110.185 255.255.255.0 secondary
ip address 10.4.158.1 255.255.255.0 secondary
ip address 10.109.111.1 255.255.255.0 secondary
ip address 192.168.100.1 255.255.255.0 secondary
ip address 192.168.22.129 255.255.255.192 secondary
ip address 10.19.250.185 255.255.255.0 secondary
ip address 10.236.80.254 255.255.255.0 secondary
ip address 10.8.21.1 255.255.255.0 secondary
ip address 10.10.23.185 255.255.255.0 secondary
ip address 10.10.50.185 255.255.252.0 secondary
ip address 192.168.219.2 255.255.255.0 secondary
ip address xxx.xx.xx6.185 255.255.255.0
ip accounting output-packets
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat inside
no ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
ip policy route-map vterm
  auto discovery qos trust
end
router rip
version 2
no validate-update-source
redistribute static
network 10.0.0.0
network 192.168.219.0
network xxx.xx.xx6.0
network xxx.xx.xx7.0
neighbor 10.10.44.185
neighbor 192.168.219.1
no auto-summary
My Switch has the following config
interface Vlan1
ip address 10.10.80.185 255.255.255.0 secondary
ip address 192.168.219.1 255.255.255.0 secondary
ip address 10.10.44.185 255.255.252.0
ip rip send version 2
end
router rip
version 2
passive-interface FastEthernet0
network 10.0.0.0
  neighbor 192.168.219.2
distribute-list 12 in FastEthernet0
no auto-summary
A host on the xxx.xx.xx6.0 network cannot ping a host on the 10.10.44.0 network.  All ports on the switch and the router are in vlan1
NormMuelleman
Can you post the ip route output?
Where are the routes not propogating to? Is it on the 3750 or the 1811?
I see one thing that caught my eye...in your switch, you have
router rip
version 2
network 10.0.0.0
no auto-summary
My thought is the command "passive-interface FastEthernet0". It's not going to send multicast updates OUT the Fa0 interface. But I am just doing a quick assessment (heck, I just took and passed my ROUTE, so my head is mush lol). But I think you said it's not working from the router to the switch.
Has this worked before? Is this a new config? Or was something done recently?
This is something I've been working on recently.  We want to move our perimeter routing back to the switch.  We have two adjacent class C (not private) and the rest are private networks.  These are listed as xxx.xx.xx
My ISP's network is yyy.yyy.yyy.x.  They have provided me a class C range.  I use NAT on the 1811.
I want to bring the xxx.xxx.xx networks off the router and have the switches perform the routing.  I don't want to do it all at once so I was hoping to get RIP to take care of the networks as I bring them over one by one.
I created the distribute list on FA0 because I want one of the Gig interfaces to be the interface to the router.  FA0 is a management interface on the 10.10.23.x network.
On the 1811, i can see that the 10.10.44.x network has been distributed from the 3750.  I underlined it.  Any routes that came from RIP or Static, on the 1811 are being seen on the 3750x but none of the connected networks.... aahhhhh... I just realized what I need to do.  I have redistribute static setup on the 1811, but not redistribute connected.  Let me try this
1811 sh ip route
     1.0.0.0/24 is subnetted, 1 subnets
C       1.1.1.0 is directly connected, Loopback0
     69.0.0.0/24 is subnetted, 1 subnets
S       69.225.150.0 [1/0] via xxx.xx.xx6.165
     172.90.0.0/24 is subnetted, 1 subnets
C       172.90.0.0 is directly connected, Vlan1
     172.99.0.0/24 is subnetted, 1 subnets
C       172.99.0.0 is directly connected, Vlan1
     172.21.0.0/16 is variably subnetted, 2 subnets, 2 masks
C       172.21.40.0/24 is directly connected, Vlan1
C       172.21.8.0/22 is directly connected, Vlan1
     172.30.0.0/24 is subnetted, 1 subnets
C       172.30.110.0 is directly connected, Vlan1
     yyy.yyy.0.0/24 is subnetted, 1 subnets
C       yyy.yyy.yy.0 is directly connected, FastEthernet1
C    192.168.219.0/24 is directly connected, Vlan1
S    192.168.232.0/24 [1/0] via xxx.xx.xx7.33
     10.0.0.0/8 is variably subnetted, 16 subnets, 2 masks
C       10.109.111.0/24 is directly connected, Vlan1
S       10.2.3.0/24 [1/0] via xxx.xx.xx6.46
S       10.2.4.0/24 [1/0] via xxx.xx.xx6.165
C       10.10.20.0/24 is directly connected, Tunnel0
C       10.10.23.0/24 is directly connected, Vlan1
C       10.8.21.0/24 is directly connected, Vlan1
R      10.10.24.0/24 [120/1] via 10.10.44.185, 00:00:24
S       10.10.44.0/22 [1/0] via 192.168.219.1
C       10.10.48.0/22 is directly connected, Vlan1
S       10.164.223.0/24 [1/0] via xxx.xx.xx6.2
C       10.4.158.0/24 is directly connected, Vlan1
C       10.162.10.0/24 is directly connected, Vlan1
C       10.170.10.0/24 is directly connected, Vlan1
C       10.173.10.0/24 is directly connected, Vlan1
C       10.236.80.0/24 is directly connected, Vlan1
C       10.19.250.0/24 is directly connected, Vlan1
     192.168.22.0/26 is subnetted, 1 subnets
C       192.168.22.128 is directly connected, Vlan1
R    192.168.1.0/24 [120/1] via 10.10.20.2, 00:00:12, Tunnel0
C    xxx.xx.xx7.0/24 is directly connected, Vlan1
C    192.168.100.0/24 is directly connected, Vlan1
     216.35.130.0/32 is subnetted, 1 subnets
S       216.35.130.98 [1/0] via xxx.xx.xx6.165
R    192.168.3.0/24 [120/1] via 10.10.20.3, 00:00:01, Tunnel0
C    xxx.xx.xx6.0/24 is directly connected, Vlan1
S*   0.0.0.0/0 [1/0] via yyy.yyy.yy.1
3750x sh ip route
Gateway of last resort is 10.10.23.185 to network 0.0.0.0
     10.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
R       10.10.20.0/24 [120/1] via xxx.xx.xx7.185, 00:00:11
                      [120/1] via xxx.xx.xx6.185, 00:00:11
                      [120/1] via 2.3.0.1, 00:00:11
C       10.10.23.0/24 is directly connected, FastEthernet0
C       10.10.24.0/24 is directly connected, Vlan2
C       10.10.44.0/22 is directly connected, Vlan1
C       10.10.80.0/24 is directly connected, Vlan1
R    192.168.1.0/24 [120/2] via xxx.xx.xx7.185, 00:00:11
                    [120/2] via xxx.xx.xx6.185, 00:00:11
                    [120/2] via 2.3.0.1, 00:00:11
R    192.168.3.0/24 [120/2] via xxx.xx.xx7.185, 00:00:11
S*   0.0.0.0/0 [1/0] via 10.10.23.185
Ok when I redistrubted the connected routes, it caused some other weirdness.  I will take another boo tomorrow
