RIP V1
Maro.Cisco
Level 2
Level 2
Hello im having a very basic topolgy where 2 routers directly connected and running RIP V1
Lo1----R1-155.10.2.1/24--------------155.10.2.2/24--R2
Lo1 is 155.10.3.1/32
Now what i know about RIP V1 is that it's Classful routing protocol so in this case R1 will advertise Lo1 to R2 without any subnet mask and when R2 recieve this it should either assign it as /24 since its in the same major network of the directly connected or /16 but in my case i can see 155.10.3.1/32 on R2 routing table how is this possible ???
R1#show run interface lo1
Building configuration...
Current configuration : 66 bytes
interface Loopback1
ip address 155.10.3.1 255.255.255.255
end
R1#show ip protocols
Routing Protocol is "rip"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Sending updates every 30 seconds, next due in 19 seconds
  Invalid after 180 seconds, hold down 180, flushed after 240
  Redistributing: rip
  Default version control: send version 1, receive any version
    Interface             Send  Recv  Triggered RIP  Key-chain
    FastEthernet0/0       1     1 2
    Loopback1             1     1 2
  Automatic network summarization is in effect
  Maximum path: 4
  Routing for Networks:
    155.10.0.0
  Routing Information Sources:
    Gateway         Distance      Last Update
    155.10.2.2           120      00:00:20
  Distance: (default is 120)
R2#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     155.10.0.0/16 is variably subnetted, 2 subnets, 2 masks
R       155.10.3.1/32 [120/1] via 155.10.2.1, 00:00:05, FastEthernet0/0
C       155.10.2.0/24 is directly connected, FastEthernet0/0
C    192.168.23.0/24 is directly connected, FastEthernet1/0
R2#show ip protocols
  Sending updates every 30 seconds, next due in 26 seconds
  Redistributing: rip
    FastEthernet1/0       1     1 2
  Maximum path: 4
    192.168.12.0
    0.0.0.0
    192.168.12.1         120      01:03:37
    155.10.2.1           120      00:00:19
cadet alain
RIPv1 will not advertise  a subnet out the same major network if the mask is different  but there is one exception and this is host routes(if routers support it and Cisco router do).
when receiving the route R2 looks for the host bit set in the host portion of the update and so applies the host mask of /32.
Alain
cadet alain
Alain
