Catalyst 3850 Switches Set up Ip address
jimmyfoddrell
My company just purchased 4 Cat 3850's. We will be stacking them. Out network Eng is out on disability, and I have to get them set up for the new office this weekend. I used the Express setup via a web browser to assign IP Addresses but after MANY attempts, for what ever reason, I am unable to access the switches using the address after I confirm the page. I even had someone witness my input to insure I had the correct address, Subnet and default gateway.  I am unfamiliar with Cisco commands, so I am unable to do it CLI. What am I missing? Any help will be greatly appreciated. Thanks.
Ton V Engelen
Level 3
Level 3
well, i m not at all familiar with the http gui, never used it. I always use the cli.
I m not sure if you want to use telnet or ssh, below is a config for ssh access.
Can you console into the switch and issue the following commands or check these commands :
enable secret 3850
username root secret 3850
(using dummy passwords "3850" here)
hostname
Ip domain-name
crypto key generate rsa
2048
interface Vlan
ip address
no shut
aaa new-model
line vty 0 4
transport input ssh
Hook up het stack to the network
Now use putty or something to setup an ssh session to the managament ip adress you configured
chandra_rc16
Level 4
Level 4
Also remember to configure the default gateway for your switches:
Command:
ip default-network
or
ip default-gateway
Whichever is applicable.
Chandu
Regards, Chandu
