RIP v2 is not working in packet tracer
numanmalik101
Hello Seniors,
I am trying to configure rip v2 in a packet tracer lab. I have added the correct routes and configured everything right.
Router to router ping is working but host to host not working fine.
Please find below the attached file and help me to solve the issue.
Thanks in advance.
3 Accepted Solutions
your PC gateways are wrong. in routers, you have used X.X.X.3 as a network IP. in PCs its X.X.X.1. change PC gateways to respective networks , .3 IP. for ex. 192.168.10.3 in PC2
Good luck
KB
the problem is not with RIPv2 but with the hosts. The default gateways on the host end with .1, while the corresponding LAN interfaces end with .3. Either change the IP address of the hosts or the LAN interfaces, so they both match.
You have actually 2 problems.  The gateway on the PC as already stated and the RIP config in R3. You forgot to enter the command version 2.  Route 192.168.60.0 is not being advertized. After that, all pinging.
Good luck
KB
thank you soo much
