06-24-2008 04:41 AM - edited 03-05-2019 11:47 PM
I've got to be missing something simple here. I have two Catalyst 4948 about 15 miles apart, connected via dark fiber. They both have base IP image.
I've been configuring RIP(version 2) to route between the switches. Static routes work fine, but when I use RIP, neither switch shows any of the routes.
The fiber is plugged into a port on each switch that is in the same VLAN.
Here's what I have configured:
Switch 1:
router rip
version 2
redistribute connected
redistribute static
Switch 2:
router rip
version 2
redistribute static
network x.x.x.x
no auto-summary
I've also tried this on the vlan interface for both sides:
interface vlanxxx
ip rip send version 2
ip rip receive version 2
Like I said, I've got to be missing something simple here.
Thanks in advance for any feedback.
Lewis
Solved! Go to Solution.
06-24-2008 05:06 AM
Switch 1 needs a network statement to enable RIP on the interface.
network statement should be of the Vlan being shared by this inter-switch link.
You may also include no auto-summary on that switch as well.
HTH,
__
Edison.
06-24-2008 05:06 AM
HTH,
__
Edison.
06-24-2008 05:23 AM
Thanks Edison,
That did the trick. I also had the wrong network statement on switch 2. Once I added that to it, Switch 2 got the routes via RIP.
Thanks again,
Lewis
