ROAS, Couldnt ping between VLANS help
givencodes
im trying to set up a new network back at the office but im having problems communicating between vlans.
i hav one router(cisco 1941) and a switch (cisco catalyst 2960g). im using the router on a stick method.
i have two vlans on the switch and i have done everything according to instructions but i still cant ping from one vlan to another. the hosts in the vlan can ping the switch, router and a;; gateways but just not other hosts.
the weird part is that the same configurations works fine in packet tracer.
here are my configurations. just check them and lemme knw where i went wrong.
FROM THE SWITCH
Current configuration : 2180 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
spanning-tree mode pvst
spanning-tree vlan 1-1005 priority 4096
vlan internal allocation policy ascending
interface GigabitEthernet0/1
switchport trunk allowed vlan 1,10,20
switchport mode trunk
interface GigabitEthernet0/2
switchport access vlan 10
switchport mode access
interface GigabitEthernet0/3
switchport access vlan 20
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
ip address 192.168.10.2 255.255.255.0
no ip route-cache
interface Vlan20
ip address 192.168.20.2 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.1
ip http server
ip http secure-server
control-plane
line con 0
line vty 5 15
end
FROM THE ROUTER:
Router#show run
Building configuration...
Current configuration : 1251 bytes
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FGL17152230
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/0.10
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
17 Replies 17
Jon Marshall
Couple of things to check -
1) the clients have their default gateways set to the router subinterface IP addresses and not the vlan interface IPs on the switch
2) if 1) is correct check for firewalls on the PCs and either allow ICMP or temporarily disable to test
Jon
hi mr jon.marshal
firstly i hav set the clients with the corresponding default getway on the router subinterface. for example if a client is in vlan 10 and on the subinterface the address is 198.162.10.1, that is the one i assigned to the client
secondly i have disabled firewall on my clients. but its still not worning.
lastly it seems that from any vlan i can ping the switch and the router subinterfaces, also any client in other vlans can successfully ping the management vlan, but a client in the management vlan or any other vlan can not ping other vlans.
help
If from a PC in vlan 10 you can ping -
1) the vlan 10 subinterface on the router
and
2) the vlan 20 subinterface on the router
then it suggests routing is fine.
So can you -
1) from the router try pinging a client in any vlan and see what happens.
Also you mention a management vlan, which vlan is that ?
Jon
the management vlan is vlan 10. okay let me try do that
well, im back...
from the router i have chekced, i can ping the switch, all clients from both vlans succesfully... i just cant figure out why i cant ping from one host in a vlan to another...also how comes in PT the very same configurations and router types works just fine??
PT does not always emulate real equipment properly.
Can you -
1) remove vlan 1 off the trunk link on the switch
2) on the switch remove the vlan 20 SVI
3) post the following -
"sh int trunk" from the switch
"sh ip route" from the router
Jon
done,
here is the output
Switch#show int trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi0/1       on               802.1q         trunking      30
Port        Vlans allowed on trunk
Gi0/1       10,20
Port        Vlans allowed and active in management domain
Gi0/1       10,20
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/1       10,20
Router#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.10.0/24 is directly connected, GigabitEthernet0/1.10
L        192.168.10.1/32 is directly connected, GigabitEthernet0/1.10
      192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.20.0/24 is directly connected, GigabitEthernet0/1.20
L        192.168.20.1/32 is directly connected, GigabitEthernet0/1.20
      192.168.30.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.30.0/24 is directly connected, GigabitEthernet0/1.30
L        192.168.30.1/32 is directly connected, GigabitEthernet0/1.30
Router#
Why is the router showing a gi0/1.30 when that is not in the config ?
Jon
hello,
i just added a vlan 30 as a native vlan
You don't need the native vlan on the trunk (which you don't have so that is good) but you also don't need a subinterface for it.
So after those changes you still cannot between vlans ?
Jon
yes i still cant, could there be a problem with the router?? or switch maybe
To be honest i don't know.
Like i say if from a PC in vlan 10 you can ping both the vlan 10 subinterface and the vlan 20 subinterface on the router then it suggests routing is working.
And you can ping from the router to each PC in both vlans so that rules out firewalls.
So the only thing i can think is default gateways but you say you have set these to be the correct router subinterfaces.
Can you post a "sh vlan brief" from the switch ?
Jon
Switch#show vlan brief
Here you go
VLAN Name                             Status    Ports
1    default                          active    Gi0/5, Gi0/6, Gi0/7, Gi0/8
                                                Gi0/9, Gi0/10, Gi0/11, Gi0/12
                                                Gi0/13, Gi0/14, Gi0/15, Gi0/16
                                                Gi0/17, Gi0/18, Gi0/19, Gi0/20
                                                Gi0/21, Gi0/22, Gi0/23, Gi0/24
10  Zimbra                           active    Gi0/2
20  Samba                            active    Gi0/3
30  native                           active    Gi0/4
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
I can't see anything wrong with your config.
When you said in one of your posts -
what did you mean by this ?
Jon
