ROAS, Couldnt ping between VLANS help
givencodes
im trying to set up a new network back at the office but im having problems communicating between vlans.
i hav one router(cisco 1941) and a switch (cisco catalyst 2960g). im using the router on a stick method.
i have two vlans on the switch and i have done everything according to instructions but i still cant ping from one vlan to another. the hosts in the vlan can ping the switch, router and a;; gateways but just not other hosts.
the weird part is that the same configurations works fine in packet tracer.
here are my configurations. just check them and lemme knw where i went wrong.
FROM THE SWITCH
Current configuration : 2180 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
spanning-tree mode pvst
spanning-tree vlan 1-1005 priority 4096
vlan internal allocation policy ascending
interface GigabitEthernet0/1
switchport trunk allowed vlan 1,10,20
switchport mode trunk
interface GigabitEthernet0/2
switchport access vlan 10
switchport mode access
interface GigabitEthernet0/3
switchport access vlan 20
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
ip address 192.168.10.2 255.255.255.0
no ip route-cache
interface Vlan20
ip address 192.168.20.2 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.1
ip http server
ip http secure-server
control-plane
line con 0
line vty 5 15
end
FROM THE ROUTER:
Router#show run
Building configuration...
Current configuration : 1251 bytes
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FGL17152230
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/0.10
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
17 Replies 17
i meant any client in other vlan can ping a host in vlan 10. but not vice versa
Right so you can -
from a PC in vlan 20 you can ping a host in vlan 10
but you can't
from a PC in vlan 10 ping a host in vlan 20
If so, can you ping the vlan 20 interface from the vlan 10 PC ?
If you can then it has to be an issue with the vlan 20 PC.
What happens if you swap the PCs around ie. change their IPs and default gateway and move them into each others ports on the switch ?
Jon
It's later over here so i'll pick this up tomorrow if no one else does.
Sorry it's taking so long to get working.
Jon
