route-map continue statement not working!
Shahzad Qadir
Visitor
Hi Guys,
Will anyone be able to have a look at it for me
version -
flash:c1841-advipservicesk9-mz.124-25f.bin
configurations:
route-map REDIST-PRI-LB-TO-5413 permit 10
match ip address prefix-list LOCAL-CPE-LO0
set community 5413:2036
route-map REDIST-PRI-LB-TO-5413 permit 20
match ip address prefix-list REDIST-LB-ROUTES-TO-5413
continue 50
set metric 0
set local-preference 150
set community 5413:3280
route-map REDIST-PRI-LB-TO-5413 deny 30
route-map REDIST-PRI-LB-TO-5413 permit 50
match ip address prefix-list LOCAL-CPE-LO10
set community 5413:2017
I can confirm routes refered in prefix-lists are in bgp table. but conitinue just don't work. If i take match statement off in seq 20 then routes are passed to neighor but not with right community and if I have match statement in seq 20 routes dont' get passed at all.
Thanks, Shahzad
Shahzad Qadir
Visitor
Anyone? This forum used to be very quick and informative a few years ago!
Hi Shahzad,
I see a few issues. For set statements under instance 50 to be applied, the prefix would need to pass both prefix-lists (instance 20 and 50). Is that the intent?
Instance 50 has a set community statement without the additive keyword. This means that if a prefix match both instance 20 and 50 prefix-lists, the second community would replace the first. Is that what you want. Please provide more information on what you are trying to achieve.
