Route-map policy and defalut route problem!
sfanayei
Can any one telle me that how I can avoid that route-map policy on vlan interface to overruled the defalut route. The mening is that I want to redirect the traffic to next-hop ip add. in route-map to get to a specific destination and other wise the traffic has to use default route . Many tanks in advance!
Bedst regards SF
andrew.prince
Level 10
Level 10
If your next hop is directly connected then use the route-map option "set ip next-hop verify-availability" which uses CDP to verify the next hop, if it is not avilable, the policy route will fail and it will consult the RIB.
HTH>
Hi HTH
Tanks for your reply. And Yes my next-hop is directtly connected and i did tryied "set ip next-hop verify-availability" . It nearly kiled my router, I had to reboot it. Have you other suggestion that I can try.
Regards SF
Well it's highly unlikely that enabling that option will kill the router, as it just looks into the
CDP table to make sure the next hop IP is there.  I would think that something else happened
at the same time.  However your options are limited when it comes to checking the avilability
of a next hop using PBR - see the below url
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gtpbrtrk.html
HTH>
