route not propagting from OSPF to eigrp
osmansmalik
Level 5
Level 5
I have Netscreen Firewall connected to a Cisco 1700 router in OSPF area 2. I also have eigrp on the same 1700 to share routes with it's eigrp neigbour Cisco 6500. I can see my eigrp neighbour Cisco 6500, i can also see OSPF routes learned by the Cisco 1700 but for some reason the routes learned from OSPF are not propagating to EIGRP. I have attached the config and any help will be really appreciated.
Nagendra Kumar Nainar
Hi Osman,
Try redistribute OSPF into EIGRP with metric set. By default, the metric while redistributing will be zero. So you may need the below command to get it work.
router eigrp 100
redistribute ospf 2 metric 100000 1 255 10 1500
Nagendra
Thanks Nagendra. That did the trick. I just had to bump up the metric higher.
Osman
