Routed Sub-interface on Catalyst 3750
eric.theodore
Community Member
I need to make sub-interfaces on a c3750-48TS but not vlan interfaces.
I'm currently unable to type any command like that:
MASTER(config)#int FastEthernet1/0/48
MASTER(config-if)#no switchport
MASTER(config-if)#int FastEthernet1/0/48.100
% Invalid input detected at '^' marker.
MASTER(config)#int FastEthernet1/0/48.100
My IOS Version is: c3750-ipservicesk9-mz.122-55.SE1
Any idea ?
6 Replies 6
N W
Level 3
Level 3
try this
Hi Noel,
Thanks for your answer...
But if you have a breif look of my previous message, i've already tried in the upper config level.
I've the same error message.
Do you have another idea ?
Kasiraman S
Level 6
Level 6
Hi Eric,
Cisco 3750 port act as a routed port and behaves like a regular router interface, except that it does not support VLAN subinterfaces
kasi
i have a 3750 infront on me running ipbase amd it handles sub - interfaces.
fine,
can you tell me the version of your IOS ?
Does your switch accept the IP vrf XXX command ?
Alvaro Garcia
Level 5
Level 5
Sub-Interfaces are not supported on 3750 switches. You would have to create a trunk port and a Layer 3 VLAN Interface.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swint.html#wp1640782
Routed Ports
A routed port is a physical port that acts like a port on a router; it does not have to be connected to a router. A routed port is not associated with a particular VLAN, as is an access port. A routed port behaves like a regular router interface, except that it does not support VLAN subinterfaces.
