Packet loss on sub interface
kaijagekironde
Community Member
Hi guys,
I have a serious problem (see attached topology)
From R1 and R2 i can ping subunterface 10.222.180.1 on R3 but with packet losses ,but i can ping the rest subinterfaces 100%.
Also from R3 i receive packet losses when i ping 10.222.180.1( which is a subinterface on it).
I tried to isolate the problem as follows;
i did put laptops on both ends of the transmission equipment and the pings were going 100% ,but with laptop on site A ,i get losses reaching 10.222.180.1 ,but with laptop on site B ,i can reach 100% on site A (10.222.180.4 and .3).
I have checked interfaces for errors ,routing issues without success.
Does any of you have an ideal what this could be?
12 Replies 12
glen.grant
   I would check your trunking setup on both the  router and the switch it goes thru, sounds like something isn't quite right.  If you can post both setups we could take a look at it   along with a show vlan from the switch.
The switch on SITE A has no vlan configured.
configs of switch on SITE B are down below;
R3#show interfaces gigabitEthernet 0/0
GigabitEthernet0/0 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0026.0b58.1f80 (bia 0026.0b58.1f80)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 12/255, rxload 2/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is T
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 2/150/18816/0 (size/max/drops/flushes); Total output drops: 23192149
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 8215000 bits/sec, 7761 packets/sec
  5 minute output rate 47727000 bits/sec, 9473 packets/sec
     2610227509 packets input, 2916520944 bytes, 7 no buffer
     Received 39744221 broadcasts, 1 runts, 0 giants, 1219 throttles
     300234 input errors, 1 CRC, 0 frame, 0 overrun, 300232 ignored
     0 watchdog, 0 multicast, 0 pause input
     1486910548 packets output, 365181245 bytes, 0 underruns
     81003 unknown protocol drops
     0 lost carrier, 0 no carrier, 151 pause output
R3
R3#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         unassigned      YES NVRAM  up                    up
GigabitEthernet0/0.178     10.222.178.1    YES NVRAM  up                    up
GigabitEthernet0/0.179     10.222.179.1    YES NVRAM  up                    up
GigabitEthernet0/0.180     10.222.180.1    YES manual up                    up
GigabitEthernet0/0.181     10.222.181.1    YES NVRAM  up                    up
GigabitEthernet0/0.183     10.1.32.82      YES NVRAM  up                    up
GigabitEthernet0/0.190     unassigned      YES unset  deleted               down
GigabitEthernet0/1         10.77.231.10    YES NVRAM  up                    up
FastEthernet0/1/0          10.1.32.86      YES manual up                    up
SSLVPN-VIF0                unassigned      NO  unset  up                    up
R3#
R3#show interfaces switchport ?
  module  Limit display to interfaces on module
  |       Output modifiers
Switch configs
SITE B_switch#show interfaces switchport
----output cut----
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: On
Access Mode VLAN: 180 (VLAN0180)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Switchport: Enabled
Operational Mode: down
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
SITEB_switch#show ip interface brief
GigabitEthernet1/0/21  unassigned      YES unset  up                    up
GigabitEthernet1/0/22  unassigned      YES unset  down                  down
GigabitEthernet1/0/23  unassigned      YES unset  up                    up
GigabitEthernet1/0/24  unassigned      YES unset  down                  down
GigabitEthernet1/0/25  unassigned      YES unset  down                  down
GigabitEthernet1/0/26  unassigned      YES unset  down                  down
GigabitEthernet1/0/27  unassigned      YES unset  down                  down
GigabitEthernet1/0/28  unassigned      YES unset  down                  down
GigabitEthernet1/0/29  unassigned      YES unset  down                  down
GigabitEthernet1/0/30  unassigned      YES unset  down                  down
SITEB_switch#show vlan
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/2, Gi1/0/47, Gi1/0/48, Gi1/0/49, Gi1/0/50, Gi1/0/51, Gi1/0/52
2    VLAN0002                         active
178  VLAN0178                         active    Gi1/0/3, Gi1/0/4, Gi1/0/5, Gi1/0/6, Gi1/0/7, Gi1/0/8, Gi1/0/9, Gi1/0/10
179  VLAN0179                         active    Gi1/0/11, Gi1/0/12, Gi1/0/13, Gi1/0/14, Gi1/0/15, Gi1/0/16, Gi1/0/17, Gi1/0/18, Gi1/0/19
180  VLAN0180                         active    Gi1/0/21, Gi1/0/22, Gi1/0/23, Gi1/0/24, Gi1/0/25, Gi1/0/26, Gi1/0/27, Gi1/0/28, Gi1/0/29, Gi1/0/30
181  VLAN0181                         active    Gi1/0/31, Gi1/0/32, Gi1/0/33, Gi1/0/34, Gi1/0/35, Gi1/0/36, Gi1/0/37, Gi1/0/38, Gi1/0/39, Gi1/0/40
183  SBG-VOIP                         active    Gi1/0/20
441  VLAN0441                         active    Gi1/0/41, Gi1/0/42
443  VLAN0443                         active    Gi1/0/43, Gi1/0/44
445  VLAN0445                         active    Gi1/0/45, Gi1/0/46
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
178  enet  100178     1500  -      -      -        -    -        0      0
179  enet  100179     1500  -      -      -        -    -        0      0
180  enet  100180     1500  -      -      -        -    -        0      0
181  enet  100181     1500  -      -      -        -    -        0      0
183  enet  100183     1500  -      -      -        -    -        0      0
441  enet  100441     1500  -      -      -        -    -        0      0
443  enet  100443     1500  -      -      -        -    -        0      0
445  enet  100445     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    srb      0      0
1004 fdnet 101004     1500  -      -      1        ieee -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
ping results
from site A R1 to R3
R1#ping 10.222.180.1 repeat 100
Sending 100, 100-byte ICMP Echos to 41.222.180.1, timeout is 2 seconds:
Success rate is 89 percent (89/100), round-trip min/avg/max = 1/3/8 ms
from R2 to R3
R2#ping 10.222.180.1 repeat 100
Success rate is 89 percent (89/100), round-trip min/avg/max = 1/3/4 ms
R2#
from R2 to R3
Tigo-FranceTel#ping 41.222.180.3 repeat 100
Sending 100, 100-byte ICMP Echos to 41.222.180.3, timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 1/1/4 ms
from R3 to R1
R3#ping 10.222.180.3 repeat 100
Success rate is 92 percent (92/100), round-trip min/avg/max = 1/3/4 ms
from R3 to R2
R3#ping 10.222.180.4 repeat 100
Sending 100, 100-byte ICMP Echos to 41.222.180.4, timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 1/3/8 ms
R3#ping 41.222.180.4 repeat 100
Success rate is 97 percent (97/100), round-trip min/avg/max = 1/3/20 ms
whew!
configure this:
ip access-list extended ICMP_ECHO
permit icmp any host 10.222.180.1 echo
ip access-list extended ICMP_ECHOREPLY
permit icmp host 10.222.180.1 any  echo-reply
class-map ICMP_RECEIVED
match access-group  name  ICMP_ECHO
policy-map ICMP_RECEIVED
class  ICMP_RECEIVED
class-map ICMP_SENT
match access-group  name  ICMP_ECHOREPLY
policy-map ICMP_SENT
class  ICMP_SENT
int g0/0.180
service-policy input  ICMP_RECEIVED
service-policy output ICMP_SENT
do your ping to R3 subinterface and post output of show policy-map interface g0/0.180
Regards.
Alain.
R3 out put:
R3#show policy-map interface g0/0.180
  Service-policy input: ICMP_RECEIVED
    Class-map: ICMP_RECEIVED (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps
      Match: access-group name ICMP_ECHO
    Class-map: class-default (match-any)
      31173 packets, 9197743 bytes
      5 minute offered rate 205000 bps, drop rate 0 bps
      Match: any
  Service-policy output: ICMP_SENT
    Class-map: ICMP_SENT (match-all)
      800 packets, 91200 bytes
      Match: access-group name ICMP_ECHOREPLY
      38665 packets, 28136623 bytes
      5 minute offered rate 581000 bps, drop rate 0 bps
      Match: any
from where you pinged ther is VLAN1 only? so apply policy-map ICMP_RECEIVED to main gig interface and clear counters command in privileged mode then ping from each router rep 100  then show same output as before but on main interface and subinterface for each router ping  and before next router ping clear counters.
Regards.
Alain.
Here we go.
from where you pinged ther is VLAN1 only? YES
Success rate is 100 percent (100/100), round-trip min/avg/max = 1/3/4 ms
R3#show policy-map interface gigabitEthernet 0/0
GigabitEthernet0/0
      0 packets, 0 bytes
      865312 packets, 103590590 bytes
      5 minute offered rate 4477000 bps, drop rate 0 bps
      Match: any
R3#show policy-map interface gigabitEthernet 0/0.180
      100 packets, 11400 bytes
      20494 packets, 13630786 bytes
      5 minute offered rate 741000 bps, drop rate 0 bps
      Match: any
R3#clear counters gigabitEthernet 0/0
Clear "show interface" counters on this interface [confirm]
R2#ping 41.222.180.1 repeat 100
Success rate is 85 percent (85/100), round-trip min/avg/max = 1/3/8 ms
GigabitEthernet0/0
      0 packets, 0 bytes
      858972 packets, 109679804 bytes
      5 minute offered rate 5794000 bps, drop rate 0 bps
      Match: any
      33717 packets, 21946418 bytes
      5 minute offered rate 964000 bps, drop rate 0 bps
      Match: any
I have just added another router R4 10.222.180.7
i can ping 10.222.180.1 100% ,as well as 10.222.180.3 and 10.222.180.4
From R1(10.222.180.4) i can reach 10.222.180.7 100% (though it stucks stucks)
new topology
  Please post the port config of the the switch that connects to R3 , it should look  like below.  You should also setup the switch for site a in the correct vlan it would make it a lot easier to troubleshoot if everything is in its correct vlan instead of trying to translate a switch that is all in vlan 1 connected to a port in vlan 180 etc...  If your trunking port does not look like this , try it and report back..
gx/x/x   --- port to R3
switchport
switchport trunk allowed vlan 178,179,180,181
switchport mode trunk
switchport nonegotiate
Also can you explain the below display it says ping 10.222.180.3  but just below that it says  41.222.180.3  , assume its just a typing error or something. All your ping examples show the same thing.
SITEB_switch#show interfaces Gi1/0/1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Access Mode VLAN: 1 (default)
Voice VLAN: none
Protected: false
3G_switch#
cadet alain
all the pings were received by the router( even though there was no match on the class-map but there was 100 matches on the replies) so there is surely something in between R3 and the routers that is dropping some packets or maybe the routers themselves.
It should be interesting to count the echo-replies on the originating routers with MQC like he did on R3.
Is there a pattern with the drops and the MQC counting ?
Regards.
Alain.
kaijagekironde
Community Member
Hi Guys,
I got the solution,
there was a command rate-limit configured on the subinterface. It was the one causing problems, after i removed it ,everything is fine now.
Thanks for your assistance.
