router 2691 with NM-16ESW module
sarahr202
Level 5
Level 5
Hi everybody
I am trying to perform this lab where i need a layer 3 switch.  I am using gns3.   I  am trying to use  router 2691with NM-16ESW module as a layer 3 switch.
h2-----vlan1--f1/1( router 2691) f1/2---vlan2-------h3
(remember in above set up, router 2691 is being used as layer 3 switch; only ports off module NM-6ESW are connected to hosts: h2 and h3)
h2 199.199.199.2
h3 193.193.193.3
Where f1/1  and f1/1 are  located on NM-16 ESW module.
Router 2691 config:
int f1/1
switchport access vlan 1
int f1/2
switchport access vlan 2
int vlan 1
ip address 199.199.199.1/24
int vlan 2
193.193.193.1/2
When i send ping packets from h1to 19.193.193.3 ( i.e h3), they are dropped.  what am i missing?
Is  something wrong with my con?
I will really appreciate any help .
thanks and have a nice weekend.
2 Accepted Solutions
Reza Sharifi
Hi Sarah,
The switch module is layer-2 only.  If you have multiple interfaces with multiple vlans, you need to configure the router itself (2691) with sub-interface and .1q for each vlan.  This way the switch performs layer-2 and the router routes between the subnets.
Have a nice weekend
Reza Sharifi
Hi Sarah,
Have a nice weekend
glen.grant
