Router ACL and Port ACL
pankaj kumar
how to find out after looking at the ACl that this is router acl and this is port acl.
is there is any syntax difference between these two acl's? or these two look the same.
Rolf Fischer
Level 9
Level 9
It depends on where the ACL is applied:
Layer-3 interface (SVI, routed port): Router ACL
Layer-2 interface (physical switch interfaces): Port ACL
Both support Standard and Extended ACLs, the Port ACLs support MAC Extended ACLs in addition.
Link: c3560 Configuring Network Security with ACLs
