Lan Base Image with 4503
May be its a newbei question. But i want to get it clarified.
My question is , if i go for any core switch bundle like
WS-C4503E-S6L-48V+
Its comes with lan base image by default. I have gone through many document , but still i confused because if i select 3560 lan base it doesnt support layer 3 like inter vlan routing. The same way with 4503 switch also, if i select lan base does it support layer 3??
Layer 3 feature like:
Inter VLAN routing
VLAN access list
DHCP server
HSRP
Thanks for your support
5 Replies 5
Collin Clark
serge123
Lan base is for layer 2
See here:
Cisco IOS XE Software LAN Base: This image provides Layer 2 features for campus access.
Cisco IOS XE Software IP Base: this image is upgradable with a software activation license (SAL). It
includes all Layer 2 features and some basic Layer 3 features. ISSU/SSO is supported in this package.
Cisco IOS XE Software Enterprise Services: This image is upgradable with a SAL; it supports full Layer 3
protocols and advanced features such as complete routing scalability, BGP, VRF, Policy-Based Routing,
and so on.
Cisco IOS XE Software Enterprise Services: This image is upgradable with a SAL; it supports full Layer 3 protocols and advanced features such as complete routing scalability, BGP, VRF, Policy-Based Routing, and so on.
Serge,
I don't believe 4500 IOS supports FULL VRF.  4500 only supports VRF-lite.
Dear All,
Does it supports inter vlan routing ?? HSRP?? Please suggest
Go here.  Fill in the details and it'll tell you exactly what your LAN Base feature set will support.
