Router Always Starting In Rommon Mode
Vikrant Ambhore
Hello Friends,
We have Cisco 1861 router, it's was working fine, If power fails then my router starts always starting in rommon
mode.
Then when i type rommon1>reset router works fine.
How can i repair it.
I need it normally starts.
Can anyone help me how to resolve this issue?
Vicky
9 Replies 9
cadet alain
Is your config register 0x2102?  do a sh ver to verify. To change in config mode type config-register 0x2102.
Regards.
Alain.
Yes i  checked it
Melbourne#sh ver
Cisco IOS Software, C1861 Software (C1861-ADVIPSERVICESK9-M), Version 12.4(24)T1
, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 19-Jun-09 14:50 by prod_rel_team
ROM: System Bootstrap, Version 12.4(11r)XW3, RELEASE SOFTWARE (fc1)
Melbourne uptime is 6 minutes
System returned to ROM by bus error at PC 0x81D0E86C, address 0x81D0E86C at 11:0
2:45 UTC Mon Dec 20 2010
System image file is "flash:c1861-advipservicesk9-mz.124-24.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C1861-SRST-F/K9 (MPC8358) processor (revision 0x300) with 249856K/12288K b
ytes of memory.
Processor board ID FHK133574R0
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
12 User Licenses
10 FastEthernet interfaces
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
128K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
Hello Vikrant, Alain,
This indeed does not seem to be caused by a corrupted config register setting.
Vikrant, can you post the entire transcript of the booting process after you power off and power on the router, including the failure to boot, the ROMMON session and your "reset" command after which the router boots up? Thank you!
Best regards,
Peter
Now router doing work fine but after few hours when power get back it's alway's going to rommon mode, & all working has been stop
but when i enter reset commad in rommon mode
Then when i type
rommon1>reset
again router works fine.
then it's  working for couple of hours, it happended 3 to 4 time,
I'm  not sure why
When I reload the router it will work fine, pls look attached
Pls look Output while reload router
User Access Verification
Username: Mark
Password:
Melbourne>ena
Melbourne>enable
Password:
*Dec 21 10:13:52.551: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=EZVPN_GROUP_1  Server_public_addr=X.X.X.X
Melbourne#reload
System configuration has been modified. Save? [yes/no]: y
Building configuration...
[OK]
Proceed with reload? [confirm]
*Dec 21 10:14:15.503: %SYS-5-RELOAD: Reload requested  by Mark on console. Reload Reason: Reload Command.
Copyright (c) 2007 by cisco Systems, Inc.
C1860 series platform with 262144 Kbytes of main memory
Readonly ROMMON initialized
program load complete, entry point: 0x80015000, size: 0xb700
program load complete, entry point: 0x80020000, size: 0x26b6648
Self decompressing the image : ############################################################################################################################################################################################################################################################################################################################################################ [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
                0X00135430 Onboard PVDM2 SIMM
                0X00003960 Onboard Ethernet
                0X0011D000 Onboard VPN
                0X000F3BB0 public buffer pools
                0X00703000 public particle pools
TOTAL:          0X00A4C940
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 10Mb.
adjusted iome size up to minimum size of: 0X00C00000
Using 4 percent iomem. [12Mb/256Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1861 Software (C1861-ADVIPSERVICESK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
export@cisco.com.
Cisco C1861-SRST-F/K9 (MPC8358) processor (revision 0x300) with 249856K/12288K bytes of memory.
12 User Licenses
Installed image archive
SETUP: new interface NVI0 placed in "shutdown" state
Press RETURN to get started!
*Dec 21 10:15:12.243: % Error opening nvram:/ifIndex-table No such file or directory
*Dec 21 10:15:13.759: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Initialized
*Dec 21 10:15:13.763: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Enabled
*Dec 21 10:15:41.859: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Dec 21 10:15:41.859: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Dec 21 10:15:42.027: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Dec 21 10:15:42.859: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
*Dec 21 10:15:43.451: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
*Dec 21 10:15:47.667: %SYS-5-CONFIG_I: Configured from memory by console
*Dec 21 10:15:48.007: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to down
*Dec 21 10:15:48.251: %SYS-5-RESTART: System restarted --
*Dec 21 10:15:48.251: %SNMP-5-COLDSTART: SNMP agent on host Melbourne is undergoing a cold start
*Dec 21 10:15:48.355: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Dec 21 10:15:48.359: %LINEPROTO-5-UPDOWN: Line protocol on Interface EDSP0, changed state to up
*Dec 21 10:15:48.371: %SYS-6-BOOTTIME: Time taken to reboot after reload =   91 seconds
*Dec 21 10:15:48.379: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Dec 21 10:15:48.379: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Dec 21 10:15:48.379: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
*Dec 21 10:15:48.399: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Dec 21 10:15:49.003: %DTP-5-TRUNKPORTON: Port Fa0/1/5 has become dot1q trunk
*Dec 21 10:15:49.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
*Dec 21 10:15:49.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to up
*Dec 21 10:15:49.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
*Dec 21 10:15:49.819: %LINK-5-CHANGED: Interface NVI0, changed state to administratively down
*Dec 21 10:15:49.819: %LINK-3-UPDOWN: Interface FastEthernet0/1/8, changed state to up
*Dec 21 10:15:49.819: %LINK-3-UPDOWN: Interface FastEthernet0/1/7, changed state to up
*Dec 21 10:15:49.819: %LINK-3-UPDOWN: Interface FastEthernet0/1/4, changed state to up
*Dec 21 10:15:49.819: %LINK-3-UPDOWN: Interface FastEthernet0/1/3, changed state to up
*Dec 21 10:15:49.819: %LINK-3-UPDOWN: Interface FastEthernet0/1/2, changed state to up
*Dec 21 10:15:49.819: %LINK-3-UPDOWN: Interface FastEthernet0/1/1, changed state to up
*Dec 21 10:15:49.819: %LINK-3-UPDOWN: Interface FastEthernet0/1/0, changed state to up
*Dec 21 10:15:50.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to down
*Dec 21 10:15:50.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/8, changed state to down
*Dec 21 10:15:50.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/7, changed state to down
*Dec 21 10:15:50.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/6, changed state to up
*Dec 21 10:15:50.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/5, changed state to up
*Dec 21 10:15:50.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/4, changed state to down
*Dec 21 10:15:50.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/3, changed state to down
*Dec 21 10:15:50.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/2, changed state to down
*Dec 21 10:15:50.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/1, changed state to down
*Dec 21 10:15:50.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/0, changed state to down
*Dec 21 10:15:52.667: %DSPRM-5-UPDOWN: DSP 2 in slot 0, changed state to up
*Dec 21 10:15:53.951: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
*Dec 21 10:15:56.159: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/7, changed state to up
*Dec 21 10:16:02.075: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/0, changed state to up
*Dec 21 10:16:02.475: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/1, changed state to up
*Dec 21 10:16:02.475: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/2, changed state to up
*Dec 21 10:16:02.475: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/3, changed state to up
*Dec 21 10:16:02.475: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/0, changed state to up
*Dec 21 10:16:02.475: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/1, changed state to up
*Dec 21 10:16:02.475: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/2, changed state to up
*Dec 21 10:16:04.023: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/3, changed state to up
*Dec 21 10:16:29.619: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=EZVPN_GROUP_1  Server_public_addr=X.X.X.X
*Dec 21 10:17:09.619: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=EZVPN_GROUP_1  Server_public_addr=X.X.X.X
*Dec 21 10:17:49.619: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=EZVPN_GROUP_1  Server_public_addr=X.X.X.X
*Dec 21 10:18:29.619: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=EZVPN_GROUP_1  Server_public_addr=X.X.X.X
*Dec 21 10:19:09.619: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=EZVPN_GROUP_1
letsgomets
Do you happen to have a modem connected to the console port of the router?
Sometimes when a modem echos back the output it actually trips the router into a ctrl-break thus putting it in RMON.
A great idea! Yes, that could be the cause. Also, possibly any device connected to the console (I am not sure about the AUX) can emit a character that may be misrepresented by the router as a break.
Best regards,
Peter
Console port is connect into System,  what should i do in this condition ?
System returned to ROM by bus error at PC 0x81D0E86C, address 0x81D0E86C at 11:02:45 UTC Mon Dec 20 2010
What is this?  Do you have any "crashinfo" file(s)?
Yep,
I had Crashinfo files in Flash, but I deleted it from Flash,
What should i do now ?
