Cisco Catalyst Switch 2960 with unmanaged switch
ssnickson
I have cisco switch 2960 and a unmanaged switch etherwan. please find the attached datasheet for your reference on the unmanaged switch. Now i using SPF module (Fibre) to connect the Gig port to the Fibre port of the unmanaged switch. The port of the unmanaged switch is not an Gig port it is 100Fx.
  1. I have checked the connection by using RJ45 link in cisco switch and the unmanged switch. I managed to ping
  2. When i connect the switch using the Gig port using fiber module i cannot ping
  3. I do know that we can buy a Gig port unmanaged switch. But in this case we have already bought the hardware
Need your advice on how to solve this issue. I need the solution for this as soon as possible
Leo Laohoo
GLC-GE-100FX is not supported on the Cisco Catalyst 2960-8TC-S, 2960-8TC-L, or 2960G-8TC-L switches.
7 Replies 7
letsgomets
On a 2960 the fiber optic ports are Gigabit ports. They will only connect at 1Gig.
100FX will not work.
Connect the ports up
Logon to the 2960 console and do the following command
"show interface g?/?"
Does it show a status of up/up and what is the speed it is connected at?
I think that is the problem you are running into.
Actaully I m using 2960-24TC-L I have attched the copy of table which i got from Cisco Website.
it stated there that GLC-FE-100FX
Description: Operates on ordinary multimode fiber-optic(MMF) link spans up to 2 kilometerslong. For 100Mbps Ethernet ports
and also i got to the that 2960 is supporting GLC-FE-100FX so does that mean if i buy GLC-FE-100FX SFP module it should be able to work?
If i stated anything wrong please advice me
Information i got from Datasheet
Cisco Catalyst 2960-S and 2960 with SFP-based ports:
10BASE-T ports: RJ-45 connectors, 2-pair Category 3, 4, or 5 UTP cabling
100BASE-TX ports: RJ-45 connectors, 2-pair Category 5 UTP cabling
1000BASE-T ports: RJ-45 connectors, 4-pair Category 5 UTP cabling
1000BASE-T SFP-based ports**: RJ-45 connectors, 4-pair Category 5 UTP cabling
1000BASE-SX -LX/LH, -ZX, -BX, -T,* -FX,* and CWDM SFP-based ports: LC fiber connectors (single/multimode fiber)
100BASE-LX, -BX, -FX SFP-based ports: LC fiber connectors (single/multimode fiber)
GLC-T and GLC-GE-100FX are not supported on the Cisco Catalyst 2960-8TC-S, 2960-8TC-L, or 2960G-8TC-L switches.
Leo Laohoo
Actaully i m using 2960-24TC-L so will it work?
Yes it should.
So if i get GLC-FE-100FX SFP module and plug it in 2960-24TC-L and Then can i work to link between unmanaged switch and Cisco Switch. The unmanaged switch is 100FX
Yes.
