ā10-20-2013 06:47 PM - edited ā03-07-2019 04:08 PM
Hi Guys,
Need some help with my 2801 router. After I power down the router it keeps on booting on rommon mode. I need to type the "reset" on rommon then the router loads the image .. Readonly ROMMON initialized.. then boots the image then user mode.. previous command where save after wr command..
Already set the following:
1. Confreg 0x2102
2. boot system flash:
Didnt encounter this problem on 2600 routers. please help.
Thank you !
ā10-20-2013 06:49 PM
Post the entire bootup process.
The IOS may have been corrupted or you have a hardware failure.
ā10-20-2013 10:13 PM
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c2801 platform with 393216 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x3818a00
Self decompressing the image : ####################################################################
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X003AA110 public buffer pools
0X00211000 public particle pools
0X00020000 Crypto module pools
0X00120000 VPM buffer pools
0X004D 0X00000000 Card in slot 0
0X0012 0X00035000 Card in slot 1
0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 22870050 bytes to IO Memory.
PMem allocated: 369098752 bytes; IOMem allocated: 33554432 bytes
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 2801 Software (C2801-ADVENTERPRISEK9_IVS-M), Version 15.1(3)T, RELEASE SOFTWARE
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 15-Nov-10 22:25 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Installed image archive
Cisco 2801 (revision 7.0) with 360448K/32768K bytes of memory.
Processor board ID FHK1450F2QL
2 FastEthernet interfaces
2 Serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
2 Voice FXO interfaces
1 DSP, 8 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
!!By default, the following "voice service voip" !!
!!sub-command is enabled: !!
!! ip address trusted authenticate !!
!!The command enables the ip address authentication !!
!!on incoming H.323 or SIP trunk calls for toll fraud !!
!!prevention supports. !!
!!Please use "show ip address trusted list" command !!
!!to display a list of valid ip addresses for incoming !!
!!H.323 or SIP trunk calls. !!
!!Additional valid ip addresses can be added via the !!
!!following command line: !!
!! voice service voip !!
!! ip address trusted list !!
!! ipv4
Press RETURN to get started!
*Oct 21 05:12:00.343: %LICENSE-6-EULA_ACCEPT_ALL: The Right to Use End User License Agreement is ac
*Oct 21 05:12:27.351: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Initialized
*Oct 21 05:12:27.355: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Enabled
*Oct 21 05:12:29.551: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to
*Oct 21 05:12:29.551: %LINK-3-UPDOWN: Interface Serial0/1/0, changed state to up
*Oct 21 05:12:29.555: %LINK-3-UPDOWN: Interface Serial0/1/1, changed state to down
*Oct 21 05:12:30.551: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0, changed state to
*Oct 21 05:12:30.555: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/1, changed state to
*Oct 21 05:12:31.175: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed stat
*Oct 21 05:12:31.175: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed stat
*Oct 21 05:12:32.855: %SYS-5-CONFIG_I: Configured from memory by console
*Oct 21 05:12:33.815: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, changed state to u
*Oct 21 05:12:34.635: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively
*Oct 21 05:12:34.635: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively
*Oct 21 05:12:37.551: %SYS-5-RESTART: System restarted --
*Oct 21 05:12:37.559: %SNMP-5-COLDSTART: SNMP agent on host R1 is undergoing a cold start
*Oct 21 05:12:37.711: %SYS-6-BOOTTIME: Time taken to reboot after reload = 199 seconds
*Oct 21 05:12:37.927: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Oct 21 05:12:37.927: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Oct 21 05:12:38.987: %DSPRM-5-UPDOWN: DSP 5 in slot 0, changed state to up
*Oct 21 05:12:39.175: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/0/0, changed state to up
*Oct 21 05:12:39.447: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/0/1, changed state to up
R1>
ā10-20-2013 10:21 PM
Looks fine, Ron.
ā10-20-2013 10:24 PM
Hi Sir Leo,
After a restart or shutdown , router boots back to rommon then I have to issue a reset command then router boots to user mode..
Thanks..
ā10-20-2013 11:21 PM
Hi Ron,
I understood that you already set the confreg as 0x2102. Could you verify the below and ensure that you have right cofig register and boot sequence
#show version
#show run | include boot
#dir flash:
example:
2600#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
2600(config)#no boot system
2600(config)#boot system flash:c2600-adventerprisek9-mz.124-12.bin
2600(config)#^Z
2600#verify flash:c2600-adventerprisek9-mz.124-12.bin
I am not seeing any known behavior on this issue, its strange the it didnt give any error message while it is going into Rommon.
Please share #show tech as well to understand the behavior.
Aru
ā10-20-2013 11:30 PM
Hi Sir,
R1#sh run | include boot
boot-start-marker
boot system flash:c2801-adventerprisek9_ivs-mz.151-3.T.bin
boot-end-marker
R1#verify flash:c2801-adventerprisek9_ivs-mz.151-3.T.bin
Verifying file integrity of flash:c2801-adventerprisek9_ivs-mz.151-3.T.bin..
.............................................................................................................................Done!
Embedded Hash MD5 : 067B7579DA60A91245F41343D3B6341E
Computed Hash MD5 : 067B7579DA60A91245F41343D3B6341E
CCO Hash MD5 : 3309D403683344906397D0A266A594A9
Embedded hash verification successful.
Thanks Sir!
ā10-20-2013 11:31 PM
R1#sh flash
-#- --length-- -----date/time------ path
1 58821536 Sep 16 2013 10:52:20 +00:00 c2801-adventerprisek9_ivs-mz.151-3.T.bin
5173248 bytes available (58822656 bytes used)
Thanks!
ā10-21-2013 11:24 PM
Any update guys. Thanks..
ā10-21-2013 11:44 PM
hi ron,
have you tried reseating the CF card and/or replaced it?
ā10-22-2013 12:33 AM
Hi Ron,
If possible, format the flash: then copy the image again. Then verify the performance and share the detail,
To determine the file system of a CF memory card, enter the show flash: all
Router# show flash: all
Partition Size Used Free Bank-Size State Copy
Mode
1 125184K 20390K 104793K 0K Read/Write
Direct
System Compact Flash directory:
File Length Name/status
addr fcksum ccksum
1 6658376 c28xx-i-mz
0x40 0xE0FF 0xE0FF
2 14221136 c2800-telcoent-mz
0x6599C8 0x5C3D 0x5C3D
[20879640 bytes used, 107308776 available, 128188416 total]
125184K bytes of ATA System Compact Flash (Read/Write)
Chip information NOT available.
1 6658376 Mar 01 2004 04:27:46 c28xx-i-mz
25268224 bytes available (6664192 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
Number of Heads: 4
Number of Cylinders 490
Sectors per Cylinder 32
Sector Size 512
Total Sectors 62720
ATA CARD FORMAT
Number of FAT Sectors 31
Sectors Per Cluster 8
Number of Clusters 7796
Number of Data Sectors 62560
Base Root Sector 155
Base FAT Sector 93
Base Data Sector 187
Refer:
Aru
