Router Cisco 4431 L3 Etherchannel
pablitomassa82
Hi Everybody,
Is L2/L3 Etherchannel supported on router CISCO 4431?
Thanks a lot
Paolo
Reza Sharifi
I think you can only do layer-3 as this is a router. The supported numbers are 1-32 and you can use LACP and mode on.
Reza Sharifi
thanks for the answer.
Did you find any documentation to prove it? i will use BASE IOS XE
thanks a lot
Paolo
