Router interface protocol is down
Lucas Okafor
Community Member
Hi everyone,
I am having an issue with with my router in packet tracer. I'm done with all configurations and I also connected a host to the router but the line protocol is still down. I don't know what i did wrong.
The whole network is from chapter 8 (ip routing)  in the Todd Lammle book "CCNA Routing and Switching".
I have attached an image showing my network.
In the image, the router labeled "corp" is connected to the "LA" and "SF" router through serial interfaces while the hosts are connected to the fast ethernet interface. I have also configure static ip route in all three routers. The serial interfaces seem to be fine, but then i can't reach the interface that the hosts are connected when i ping the network.
Please can someone help me with a solution.
Lucas
Your interface fa0/0 on router is in up down state. So it can't work.
- change cable type to cross-over
- speed and duplex to auto on router - or - you need to change speed and duplex accordingly on PC.
6 Replies 6
Mark Malone
do the pcs have a default gateway set
what static routes do you have in place
Hi Mark Malone,
I didn't set a default gateway on the pcs.
I set the ip configuration on the pcs to recieve ip through dhcp.
The "Corp" router is configured as a DHCP server and it's meant to offer ip addresses to the pcs in the "LA" and "SF" LAN
The static routes are
Corp router configuration:
Corp(config)#ip route 192.168.10.0 255.255.255.0 172.16.10.2 150
Corp(config)#ip route 192.168.20.0 255.255.255.0 s0/1 150
SF router configuration:
SF(config)#ip route 10.10.10.0 255.255.255.0 172.16.10.1 150
SF(config)#ip route 172.16.10.4 255.255.255.252 172.16.10.1 150
SF(config)#ip route 192.168.20.0 255.255.255.0 172.16.10.1 150
LA router configuration:
LA(config)#ip route 10.10.10.0 255.255.255.0 172.16.10.5 150
LA(config)#ip route 172.16.10.0 255.255.255.252 172.16.10.5 150
LA(config)#ip route 192.168.10.0 255.255.255.0 172.16.10.5 150
I've also included a zip file containing a packet tracer file of the network. console password is console
Thanks crni00000 i changed the cross-over cable and the duplex to auto and everything is all good now.
I LOVE YOU SO MUCH!!! ❤️❤️
Dan Lukes
By the way, you are asking in wrong place.
Packet Tracer tool is not free tool and there's no community dedicated to it.
Packet Tracer is learning tool. You should ask in appropriate community of Cisco Learning Network.
