Showing results forĀ
Search instead forĀ
Did you mean:Ā
Router keep reloading when url filter is enabled
joshiaroon
we have 7206 router with 128mb RAM. when we enable http url filtering feature the router keeps reloading showing the following error
Jul  9 23:56:20: %URLF-3-SERVER_DOWN: Connection to the URL filter server 10.40.2.26 is down
Jul  9 23:57:17: %SCHED-3-STUCKMTMR: Sleep with expired managed timer 62F982C0, time 0x9200D1E54 (00:00:00 ago).
-Process= "URL filter proc", ipl= 4, pid= 76
-Traceback= 607BE084 607BE4DC 608E59E8 608E5C9C 608E93F8 6098D808 609932AC 61068A18 6106953C 610680E4 61068470
Jul  9 23:57:17: %URLF-5-SERVER_UP: Connection to an URL filter server(10.40.2.26) is made, the router is returning from ALLOW MODE
Jul  9 22:58:35: %ALIGN-3-SPURIOUS: Spurious memory access made at 0x6106B980 reading 0x4
Jul  9 22:58:35: %ALIGN-3-TRACE: -Traceback= 6106B980 61057928 61057ACC 6105830C 61036C98 61036420 61034960 6060E200CMD: 'copy run start' 22:59:49 EDT Fri Jul 9 2010
After we remove the url feature , the router is stable. Can some one know whats the problem?
Giuseppe Larosa
Hello Joshi,
the process URL filter uses too much cpu time. There is a protection mechanism called watchdog that actively monitors cpu usage by other processes.
When a process stucks the cpu the watchdog may even trigger a reload in an attempt to free the main cpu resources.
you have a quite old NPE on it if it has only 128 MB  of RAM I'm afraid you cannot use this feature on this box, not without some tuning at least.
the feature may not be supported on your IOS image and hardware.
for going you should provide additional information
show ver
configuration of URL filtering and for what you use it
do not post usernames/passwords and change public ip addresses in private ip addresses for your safety.
Hope to help
Giuseppe
Ganesh Hariharan
URLF-3-SERVER_DOWN:Connection to the URL filter server  10.40.2.26 is down
In this message, the router has lost contact with the  content-filtering server (10.40.2.26). If you have configured a secondary  server, the router establishes contact with it.
%URLF-3-ALLOW_MODE:Connection to all URL filter servers are down and ALLOW MODE is OFF
If the primary (or secondary) servers fails and no other  content-filtering server is available, you will see this message. The  router goes into an allow mode, in which all HTTP connections either are  allowed or are denied.
%URLF-5-SERVER_UP:Connection to an URL filter server  is made, the system is returning  from ALLOW MODE
If CBAC inspection for HTTP has entered the allow mode and then  successfully restores connectivity to a content-filtering server, you  will see this message.
Check out the below link on other error messages
http://cisco.biz/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6a69.shtml#ts1
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
