07-12-2010 12:40 AM - edited 03-06-2019 11:59 AM
Hi All ,
We have Cisco 877W router, it is disconnecting more frequently
Apparently it disconnected some times and not attempt to re-connect Automatic ,
If i does restart Router then it works again for a while, When I lost Internet then i am able to ping Router from system, but Router Adsl & CD light is off but power light is on.. i'm not sure why it's happended.
we have Static IP, we have only one issue if it's disconnects from the internet and doesn’t attempt to reconnect, it should be connect Automatically but If i does restart Router then it works again, probably it seems to when drop out and not attempt to re-connect, possibly the setting for re-connecting are an issue,
Can any one help me on this issue ?
Vikrant
Cisco877#sh run Building configuration... Current configuration : 6595 bytes ! version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname Cisco877 ! boot-start-marker boot-end-marker ! enable password 7 00291215105E19565E ! no aaa new-model ! crypto pki trustpoint TP-self-signed-2180976684 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-2180976684 revocation-check none rsakeypair TP-self-signed-2180976684 ! ! crypto pki certificate chain TP-self-signed-2180976684 certificate self-signed 01 30820240 308201A9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030 31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274 69666963 6174652D 32313830 39373636 3834301E 170D3032 30333034 30333238 32345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649 4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 31383039 37363638 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281 8100AD41 2BD98F7F B90AD9D9 001F605C 43712F5C 18ADB1C9 1B9C4E16 D8D81761 56E7FFE7 770BCDAC 9FE0F311 883B0C1F E83AF85B BDBA30F4 19913775 C7C1B80B 4881E1A3 F69658A8 5FF5F9DD F5DC7BBC C8C1023D 4D346F56 A5212BE2 F4BC3270 61F1CCAD 03322ECF 40204E44 1981D877 EC45772F 96564D5F 9DA8FFA3 5D7AF261 452B0203 010001A3 68306630 0F060355 1D130101 FF040530 030101FF 30130603 551D1104 0C300A82 08436973 636F3837 37301F06 03551D23 04183016 80142AC9 29A49C8A 3773FBFA FF48D220 9351888D 432E301D 0603551D 0E041604 142AC929 A49C8A37 73FBFAFF 48D22093 51888D43 2E300D06 092A8648 86F70D01 01040500 03818100 88DE784D 1AE0CD20 F44B0BBC 4C8BA8AE 435BADF8 12952901 A661D095 80760055 8BE81AED F2B7D27D F5DCD863 19C87654 1D498D82 1C8EDA83 C21A8FFE C449CDDE 8EA33BF0 2CEB7D78 590C9650 86541C1D 40A264DE 5DBBAECF F4EE6E02 10FD2179 01180EDA F7BD1319 0B59B8C8 3B4ACF0C 18740644 F3E4A971 00CFDBD7 884CB7 14 quit dot11 syslog ! dot11 ssid melbourne vlan 1 authentication open authentication key-management wpa guest-mode wpa-psk ascii 7 055B525E701C18504D5140 ! ip cef ! ! no ip dhcp use vrf connected ip dhcp excluded-address 192.168.8.1 192.168.8.10 ! ip dhcp pool LAN-POOL import all network 192.168.8.0 255.255.255.0 default-router 192.168.8.1 dns-server 192.168.8.1 option 150 ip 10.1.1.1 option 66 ip 192.168.8.1 lease 0 2 ! ip dhcp pool lan-pool ! ! ip name-server 198.142.0.51 ip name-server 203.2.75.132 ip auth-proxy max-nodata-conns 3 ip admission max-nodata-conns 3 ! multilink bundle-name authenticated ! ! username admin privilege 15 password 7 XXXXXXXXX ! ! crypto isakmp policy 1 encr 3des authentication pre-share group 2 ! crypto isakmp policy 10 encr aes 256 hash md5 authentication pre-share group 5 lifetime 28800 crypto isakmp key XXXXXXXXX address XXXXXXXXX ! ! crypto ipsec transform-set LAB-Transform esp-aes 256 esp-md5-hmac crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac ! ! ! crypto ipsec client ezvpn AustraliaVPN connect auto group EZVPN_GROUP_1 key Coinopsolutions.com mode network-extension peer XXXXXXXXX username XXXXXXXXX password XXXXXXXXX xauth userid mode local ! ! archive log config hidekeys ! ! ! bridge irb ! ! interface ATM0 no ip address no atm ilmi-keepalive dsl operating-mode auto ! interface ATM0.1 point-to-point pvc 8/35 pppoe-client dial-pool-number 1 ! ! interface FastEthernet0 duplex full speed 100 ! interface FastEthernet1 duplex full speed 100 ! interface FastEthernet2 duplex full speed 100 ! interface FastEthernet3 duplex full speed 100 ! interface Dot11Radio0 no ip address ip nat inside ip virtual-reassembly ! encryption vlan 1 mode ciphers tkip ! ssid melbourne ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0 station-role root ! interface Dot11Radio0.1 encapsulation dot1Q 1 native no cdp enable bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Vlan1 no ip address ip nat inside ip virtual-reassembly ip tcp adjust-mss 1412 bridge-group 1 bridge-group 1 spanning-disabled ! interface Dialer0 mtu 1492 ip address negotiated ip mtu 1452 ip nat outside ip virtual-reassembly encapsulation ppp ip route-cache flow ip tcp adjust-mss 1452 dialer pool 1 dialer-group 1 ppp authentication pap callin ppp chap refuse ppp pap sent-username XXXXXXXXX password 7 XXXXXXXXX 00 crypto ipsec client ezvpn AustraliaVPN ! interface BVI1 ip address 192.168.8.1 255.255.255.0 ip nat inside ip virtual-reassembly crypto ipsec client ezvpn AustraliaVPN inside ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 Dialer0 ip route 0.0.0.0 0.0.0.0 ATM0 ip route 192.168.8.0 255.255.255.0 Dialer0 ! ! ip http server ip http authentication local ip http secure-server ip dns server ip nat inside source list ToNAT interface Dialer0 overload ! ip access-list extended ToNAT permit ip 192.168.8.0 0.0.0.255 any deny ip 192.168.8.0 0.0.0.255 192.168.2.0 0.0.0.255 deny ip 192.168.8.0 0.0.0.255 192.168.4.0 0.0.0.255 ip access-list extended acl_vpn permit ip 192.168.8.0 0.0.0.255 192.168.2.0 0.0.0.255 permit ip 192.168.8.0 0.0.0.255 192.168.4.0 0.0.0.255 ! logging 192.168.8.12 access-list 40 permit 192.168.2.0 0.0.0.255 access-list 50 permit 192.168.0.0 0.0.255.25 access-list 100 permit ip 192.168.1.0 0.0.0.255 any access-list 100 permit ip 192.168.2.0 0.0.0.255 any access-list 100 remark SDM_ACL Category=4 access-list 100 permit icmp 192.168.2.0 0.0.0.255 any access-list 100 remark SDM_ACL Category=4 access-list 101 permit icmp 192.168.2.0 0.0.0.255 any access-list 101 remark IPSec Rule access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255 access-list 103 remark IPSec Rule access-list 103 permit ip 192.168.8.0 0.0.1.255 XXXXXXXXX 0.0.0.63 access-list 104 remark SDM_ACL Category=4 access-list 104 permit gre host 192.168.8.1 host XXXXXXXXX dialer-list 1 protocol ip permit ! ! ! route-map SDM_RMAP_1 permit 1 match ip address 100 ! ! control-plane ! bridge 1 route ip ! line con 0 password 7 072C2E4342081E003743525B56 login local no modem enable line aux 0 password 7 072C2E4342081E003743525B56 login local ! scheduler max-task-time 5000 end
07-12-2010 06:32 AM
Are you having this problems with wireless clients or all clients. When the problem happen can you ping an external source from the router like 4.2.2.2. Which IOS you are running.
07-12-2010 07:01 AM
Thanks for your reply,
I'm having this problems with all clients, When I lost Internet then i am able to ping Router from system, but unable to ping an external source from the router also client system, If i restarted Router then it works again for while. It seems to when drop out and not attempt to re-connect, possibly the setting for re-connecting are an issue,
We are using Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(15)T5,RELEASE SOFTWARE (fc4)
Pls help
vikrant
07-13-2010 05:32 AM
Vikrant
I do not see any problem with the config. I am not sure what might be the problem. That router is a new install?
07-13-2010 08:10 PM
Hello Luis Ruiz,
I hope you are doing well,
I configured router newly, is there any way to find out issue ? or do you have any idea? & what should i do now ? please suggest
Vikrant
07-14-2010 06:54 AM
Vikrant
I can't see why is behaving like that. If you have an older router and that problem did not exist with the older one. Maybe is a bug with the new cisco router ios. But I am not sure you do have to look at cisco bug page.
Luis
07-15-2010 10:27 PM
