Router on a stick intermittent ping. Cisco 1921 ISR, Catalyst 2950
bcg_81
Thanks ahead for anyone's time who assist.
I setup a Cisco 1921 with a RoaS configuration and pinging to the interfaces from all three vlans is intermittent. Below is a copy of the ping from PC, router config, switch config.
Ethernet adapter VMware Network Adapter VMnet8:
C:\Users\Brian>ping 192.168.3.1
Pinging 192.168.3.1 with 32 bytes of data:
Reply from 192.168.3.1: bytes=32 time<1ms TTL=255
Reply from 192.168.3.1: bytes=32 time=1ms TTL=255
Ping statistics for 192.168.3.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\Users\Brian>ping 192.168.100.1
Pinging 192.168.100.1 with 32 bytes of data:
Reply from 192.168.100.1: bytes=32 time<1ms TTL=255
Reply from 192.168.100.1: bytes=32 time=1ms TTL=255
Ping statistics for 192.168.100.1:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\Users\Brian>ping 10.1.150.1
Pinging 10.1.150.1 with 32 bytes of data:
General failure.
Reply from 10.1.150.1: bytes=32 time=3ms TTL=255
Reply from 10.1.150.1: bytes=32 time=2ms TTL=255
Ping statistics for 10.1.150.1:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 2ms, Maximum = 3ms, Average = 2ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\Users\Brian>ipconfig
Windows IP Configuration
Wireless LAN adapter Local Area Connection* 1:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Wireless LAN adapter Local Area Connection* 2:
Ethernet adapter VMware Network Adapter VMnet1:
Link-local IPv6 Address . . . . . : fe80::d9:b6e:f3cf:c7d4%16
IPv4 Address. . . . . . . . . . . : 192.168.182.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
Link-local IPv6 Address . . . . . : fe80::899b:f181:9fcb:e95d%20
IPv4 Address. . . . . . . . . . . : 192.168.23.1
Ethernet adapter Ethernet 3:
Link-local IPv6 Address . . . . . : fe80::4d7b:1c7d:2683:28c4%5
IPv4 Address. . . . . . . . . . . : 10.1.150.2
Subnet Mask . . . . . . . . . . . : 255.255.255.224
Default Gateway . . . . . . . . . : 10.1.150.1
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : attlocal.net
IPv6 Address. . . . . . . . . . . : 2600:1700:1230:4330::47
IPv6 Address. . . . . . . . . . . : 2600:1700:1230:4330:c945:f5e0:7e70:2288
Temporary IPv6 Address. . . . . . : 2600:1700:1230:4330:198a:ab8:fcb0:1a06
Link-local IPv6 Address . . . . . : fe80::c945:f5e0:7e70:2288%17
IPv4 Address. . . . . . . . . . . : 192.168.1.112
Default Gateway . . . . . . . . . : fe80::a9b:b9ff:fe32:1b32%17
192.168.1.254
Request timed out.
Request timed out.
General failure.
Request timed out.
Reply from 10.1.150.1: bytes=32 time<1ms TTL=255
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Router
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$xE.8$GCHpcWyhpzOXfKdU61.pu0
no aaa new-model
ethernet lmi ce
memory-size iomem 15
ip dhcp excluded-address 192.168.100.1
ip dhcp excluded-address 192.168.100.200
ip dhcp excluded-address 192.168.3.1
ip dhcp excluded-address 10.1.150.1
ip dhcp pool VOLT_DHCP_POOL
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
dns-server 4.2.2.2 8.8.8.8 4.2.2.3
lease 7
ip dhcp pool VOLT_MGMT_DHCP_POOL
network 192.168.3.0 255.255.255.224
default-router 192.168.3.1
ip dhcp pool VOLT_SERVER_DHCP_POOL
network 10.1.150.0 255.255.255.224
default-router 10.1.150.1
ip domain name voltbroadband.org
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FJC2106L289
license accept end user agreement
license boot module c1900 technology-package datak9
username admin password 7 044D5B0A1B7019614C
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description **RoaS**
no ip address
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/0.1
interface GigabitEthernet0/0.3
description **VLAN 3, MGMT**
encapsulation dot1Q 3
ip address 192.168.3.1 255.255.255.224
interface GigabitEthernet0/0.99
encapsulation dot1Q 99 native
ip address 192.168.99.1 255.255.255.0
interface GigabitEthernet0/0.100
description **VLAN 100, STAFF**
encapsulation dot1Q 100
ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet0/0.150
description **VLAN 150, Servers**
encapsulation dot1Q 150
ip address 10.1.150.1 255.255.255.224
interface GigabitEthernet0/1
description ****IP WILL CHANGE, EXIT INTERFACE, NEED STATIC****
ip address 10.10.10.10 255.255.255.0
ip nat outside
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip http secure-server
ip nat source list VOLT_SERVER_NAT interface GigabitEthernet0/1 overload
ip nat inside source list VOLT_MEMBERS_NAT interface GigabitEthernet0/1 overload
ip ssh version 2
ip access-list standard VOLT_SERVER_NAT
permit 10.1.150.0 0.0.0.224
ip access-list standard VOLT_STAFF_NAT
permit 192.168.100.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 3
exec-timeout 5 0
password 7 095A1E050D54423D4E
login local
transport input ssh
line vty 4
exec-timeout 5 0
login local
transport input ssh
scheduler allocate 20000 1000
end
Switch
hostname SW1
enable secret 5 $1$02x8$zG.m1XxNgmVe0bJ1qxKwT0
username admin password 7 08371C421D485047574B
clock timezone CST -6
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
description **STAFF, VLAN100**
switchport access vlan 100
switchport mode access
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
description **SERVERS, VLAN150**
switchport access vlan 150
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
description **MGMT, VLAN3**
switchport access vlan 3
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no ip address
no ip address
interface GigabitEthernet0/2
switchport trunk native vlan 99
switchport trunk allowed vlan 3,100,150
switchport mode trunk
no ip address
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan3
ip address 192.168.3.30 255.255.255.224
ip helper-address 192.168.3.1
no ip route-cache
interface Vlan99
ip address 192.168.99.250 255.255.255.0
no ip route-cache
interface Vlan100
no ip address
no ip route-cache
shutdown
interface Vlan150
no ip address
ip helper-address 10.1.150.1
no ip route-cache
shutdown
ip default-gateway 192.168.99.1
ip http server
line con 0
line vty 0 4
exec-timeout 60 0
password 7 120F551B065A59546F
login
line vty 5 15
login
end
make the changes marked in bold. When you are finished, post the revised configs again so we can double-check.
Router
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
lease 7
ip cef
no ipv6 cef
redundancy
no ip address
shutdown
no ip address
ip nat inside
duplex auto
speed auto
--> ip nat inside
--> ip nat inside
--> ip virtual-reassembly in
--> ip nat inside
--> ip nat inside
ip nat outside
--> no shutdown
duplex auto
speed auto
no ip http server
--> no ip nat source list VOLT_SERVER_NAT interface GigabitEthernet0/1 overload
--> no ip nat inside source list VOLT_MEMBERS_NAT interface GigabitEthernet0/1 overload
--> ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip ssh version 2
--> no ip access-list standard VOLT_SERVER_NAT
--> no ip access-list standard VOLT_STAFF_NAT
--> access-list 1 permit 192.168.3.0 0.0.0.31
--> access-list 1 permit 192.168.99.0 0.0.0.255
--> access-list 1 permit 192.168.100.0 0.0.0.255
--> access-list 1 permit 10.1.150.0 0.0.0.31
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 3
exec-timeout 5 0
login local
transport input ssh
line vty 4
exec-timeout 5 0
login local
transport input ssh
end
Switch
hostname SW1
--> no ip subnet-zero
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip address
no ip route-cache
shutdown
--> no interface Vlan3
no ip route-cache
interface Vlan99
no ip route-cache
--> no interface Vlan100
no ip address
no ip route-cache
shutdown
--> no interface Vlan150
no ip address
no ip route-cache
shutdown
ip http server
line con 0
line vty 0 4
exec-timeout 60 0
login
line vty 5 15
login
end
Router
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
lease 7
ip cef
no ipv6 cef
redundancy
no ip address
shutdown
no ip address
ip nat inside
duplex auto
speed auto
--> ip nat inside
--> ip nat inside
--> ip nat inside
--> ip nat inside
ip nat outside
--> no shutdown
duplex auto
speed auto
no ip http server
ip ssh version 2
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 3
exec-timeout 5 0
login local
transport input ssh
line vty 4
exec-timeout 5 0
login local
transport input ssh
end
Switch
hostname SW1
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip address
no ip route-cache
shutdown
no ip route-cache
interface Vlan99
no ip route-cache
no ip address
no ip route-cache
shutdown
no ip address
no ip route-cache
shutdown
ip http server
line con 0
line vty 0 4
exec-timeout 60 0
login
line vty 5 15
login
end
Thank you for the help, I have a lot to learn.
After I made the changes, my original test failed, but then I was able to ping all the interfaces multiple times across multiple vlans.  I took a 3 minute break and then the pings go back to being intermittent.  Ill attached the router, switch and then the ping test that made from 3 of the 4 vlans.
Router
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
lease 7
ip dhcp pool VOLT_STAFF_DHCP_POOL
lease 7
lease 7
ip cef
no ipv6 cef
username admin password 7 1313471E1F5D517A6E647966
redundancy
no ip address
shutdown
no ip address
ip nat inside
no ip virtual-reassembly in
duplex auto
speed auto
description **VLAN3, MGMT**
ip nat inside
ip nat inside
ip nat outside
duplex auto
speed auto
no ip http server
ip ssh version 2
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 3
exec-timeout 5 0
login local
transport input ssh
line vty 4
exec-timeout 5 0
login local
transport input ssh
end
Switch
hostname SW1
ip subnet-zero
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan9
no ip address
no ip route-cache
shutdown
interface Vlan99
no ip address
no ip route-cache
shutdown
ip default-gateway 192.168.3.1
ip http server
line con 0
line vty 0 4
exec-timeout 60 0
login
line vty 5 15
login
end
Ping CMD
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.100.1: bytes=32 time=2ms TTL=255
Reply from 192.168.100.1: bytes=32 time=3ms TTL=255
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\Users\Brian>192.168.3.1
'192.168.3.1' is not recognized as an internal or external command,
operable program or batch file.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>do show run
'do' is not recognized as an internal or external command,
IPv4 Address. . . . . . . . . . . : 192.168.100.2
Default Gateway . . . . . . . . . : 192.168.100.1
Temporary IPv6 Address. . . . . . : 2600:1700:1230:4330:c432:f3c3:5da7:52db
192.168.1.254
C:\Users\Brian>ip config /release
'ip' is not recognized as an internal or external command,
C:\Users\Brian>ip config /renew
C:\Users\Brian>ipconfig /release
No operation can be performed on Local Area Connection* 1 while it has its media disconnected.
C:\Users\Brian>ipconfig /renew
No operation can be performed on Local Area Connection* 2 while it has its media disconnected.
192.168.1.254
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
An error occurred while renewing interface Ethernet 3 : The name specified in the network control block (NCB) is in use on a remote adapter.
The NCB is the data.
IPv4 Address. . . . . . . . . . . : 192.168.3.2
Default Gateway . . . . . . . . . : 192.168.3.1
192.168.1.254
192.168.1.254
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
C:\Users\Brian>
192.168.1.254
C:\Users\Brian>ping 10.1.150.10
Pinging 10.1.150.10 with 32 bytes of data:
Reply from 10.1.150.10: bytes=32 time=1ms TTL=63
Ping statistics for 10.1.150.10:
Minimum = 1ms, Maximum = 1ms, Average = 1ms
Reply from 10.1.150.1: bytes=32 time=1ms TTL=255
192.168.1.254
C:\Users\Brian>
Reply from 10.1.150.1: bytes=32 time=56ms TTL=255
Minimum = 0ms, Maximum = 56ms, Average = 14ms
Reply from 10.1.150.10: bytes=32 time<1ms TTL=63
C:\Users\Brian>ping 192.168.99.1
Pinging 192.168.99.1 with 32 bytes of data:
Reply from 192.168.99.1: bytes=32 time<1ms TTL=255
Reply from 192.168.99.1: bytes=32 time=1ms TTL=255
Ping statistics for 192.168.99.1:
192.168.1.254
Reply from 10.1.150.10: bytes=32 time=1ms TTL=64
Reply from 10.1.150.10: bytes=32 time<1ms TTL=64
192.168.1.254
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 12.83.102.9: Destination net unreachable.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
C:\Users\Brian>
Thank you. I'll need to revisit this configuration because part of my problem was a switchport flapping. I had to move to simpler configuration due to time constraints. I also saw an article where someone else was having issues with RoaS on the 1900 series.
