Router WAN interface
dahgenegweon
Community Member
If someone needs to have 2 x WAN interface in a Cisco Router,
does it usually mean serial interface or there is simply no way to figure out only from this content?
I am confused since WAN interface is a logical concept compared to
physical ports such as Giga Ethernet Interface or Serial Interface.
Thank you in advance
Leo Laohoo
Could be any interface.  Serial, fibre, copper ...
Main thing is the interface(s) must be a routable port.
lawsonad
WAN Interface is not referring to any specific physical interface type or medium. Instead WAN is a logical description of any interface that performs WAN type functionality.
"If someone needs to have 2 x WAN interface in a Cisco Router, does it usually mean serial interface or there is simply no way to figure out only from this content?"
Correct, absolutely zero way to tell from that statement alone.
"I am confused since WAN interface is a logical concept compared to physical ports such as Giga Ethernet Interface or Serial Interface."
You are correct.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Most likely meaning of 2 x WAN interfaces would be two interfaces that support typical WAN links, e.g. dedicated T1/E1, ISDN, frame-relay, ATM, POS, etc.
Today, most modern Cisco router's WAN interfaces tend to be modular, so you can select the "right" WAN interface.
