Router with 2xWan ETH + 3G + LAN
Hello everyone,
My name is Rafael and I need your help at this moment.
Im engaged in a project wich demands a router of "small business series" with two interfaces wan ETH + 3G embedded + LAN interface.
I was taking a look on router 819 that will fit perfectly but it  has only one Wan interface.
I was wondering if is it possible to transform some of LAN interface as a WAN interface?
Or cisco has any other model that fits my demand?
Just including a information, I find out two wan interfaces in the model 891, however, 3g interface its not included.
Is it possible using USB interface as 3G interface? Or would be necessary using a LAN interface with a modem?
Best regards,
Rafael
jurodri3
Hello Mr. Duarte,
I have checked and apparently is not possible to transform one of the LAN ports as a WAN port.
In that case I would recommend you a device Dual WAN as RV042 or RV082. That would fit your requirements
Diego Rodriguez
Cisco network engineer
Thank you
*If this answer was satisfactory for you, please mark the question as Answered.*
