11-23-2006 11:31 PM - edited 03-05-2019 01:00 PM
Which is the cheaper Cisco router where PRI ports can be equipped?
many tks
simone
Solved! Go to Solution.
11-24-2006 12:30 AM
You can go for Cisco 1700 Series router. Below is the link with specifications,
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088715.html
Hope that helps
Suresh Jain
Log in to Community
