Routing a DSL connection over Cisco Infrastructure
leeharvey85
We want to route a DSL connection from one switchport (connected with a DSL Router) of a Cisco Catalyst 3650 in the bureau space to one switchport (connected with a end-device) of a Cisco Nexus environment (5548/2248) in the technical room. The dsl connection should only be available on this two switchports and should not have interaction with the internal network. Our idea was to set up a separate VLAN for the dsl connection. Is this the right way? Is it possible to route the DSL connection over a configured trunk port (Cisco Catalyst) to a configured trunk port (Cisco Nexus) only in this specific VLAN?
Jon Marshall
Matthias
Yes you can have a dedicated vlan for this connection.
You simply create a new vlan and extend it all the way back to the switchport that connects to the end device.
If the end device is only going to be used to connect via the DSL ie. it does not need connectivity to any other devices in any other vlans then there is no need for any SVIs for that vlan. You simply set the default gateway of the end device to be the DSL router.
So the only ports in that vlan are the DSL router and the end device. The trunk links between switches also need to allow this vlan.
With this setup the end device would only be able to communicate with the DSL router and nothing else.
Jon
Jon
Thanks for the answer. Seems that i had the right idea. My concern was that the end devices in the other VLANs get the IP adresses of the DSL Router (with activated DHCP) if i choose the wrong configuration.
One more question:
Do i have to configure both switchports - the one connected to the DSL router and the one connected to the end device - as trunk ports and configure the 'DSL - VLAN' (VLAN 112) as Trunking VLAN?
Like this:
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 200 (client neu)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: 17 (VOIP-OG1)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: 112
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Matthias
Matthais
You don't need to configure the switchports connecting to the end device and the DSL router as trunks. You just configure them as access ports in vlan 112.
The switch interconnects are presumably trunks so you need to -
1) make sure vlan 112 is in the vlan database on both switches
and
2) allow vlan 112 on the trunk links
and there should be no SVIs  for vlan 112 on either switch as they are not needed.
This would mean only the end device and the DSL router are in vlan 112 and no other device could get a DHCP address from the DSL router.
Jon
