routing between 2 subnets
Yea9632
Level 3
Level 3
it's maybe a "stupid" question but i'm just confused
a friend of me trying to configure a VPN tunnel, by making a "random" topology which i didn't understand ( or maybe i'm not used to see it so often because it's just random)
the topology looks like this :
PC1 ==== Switch 1 ==== ASA 1/================/ASA 2====Switch2====PC2
192.168.1.0/24============/     10.10.10.0/24        /===========192.168.2.0/24
as you can see we have 3 networks here, each ASA is connected to 2 different networks, and we can do a ping from PC1 to ASA2 outside interface without configuring static/dyn. routing
why i can ping ? simply because we have a server with 2 nic's, it allows traffic to pass ?
and we can't ping from PC1 to the inside interface of ASA2 ( following the same rule, normally it should ?! )
i'm not used to see such topology, this is not the problem, my problem now, how can i understand this ?
PS: i'm used to see big architectures and topology, and i know where/ when should i use routing and where's not necessary, but small things sometimes make me feel ridiculous
any help ?
Chandra Gurung
Community Member
I might be wrong but doesn't by default interfaces of the ASA kill the ping traffic, if the network is setup correctly you might be able to ping PC2 or Switch2 but not ASA2 inside interface from PC1.
So you mean , with 2 nic's, even we have different networks, no need to use a router, the traffic should pass ? i mean we can reach PC2 from PC1 ?
I think the main point is security-level. but as far as I am aware you do need routes configured.. be it static or dynamic for two subnets to talk to each other.
that was my thought, but he didn't configured any routes there (static or dynamic )... asked myself : how he can do a ping between PC1 and the inside interface of the ASA 2
ASA isn't configured yet, so my question is just about how the routing works here , if ASA in some sort works like a router ( in term of isolating subnets ) , so absolutely we need to configure routes ..
