Routing between Cisco 1720 and PIX 501
jay.johnson1
I'm currently attempting to run a 1720 as an edge router with a PIX 501 behind it. As of now, I can pull a public IP on the 1720's WAN interface (I'm using a WIC-1ENET card with broadand) but I can't get any activity from the fa0 port.
However, if I when I put a Linksys WRV200 in front of the pix, I can pass traffic to the computers sitting behind the pix and route without any issues.
My goal is to remove SOHO devices from gateway positions and use industry rated hardware instead. Provided I get some responses, I'll post configs if need be.
Jay
Certified: CCNA (R/S, Security, Voice), CCDA, CCNP (R/S)
15 Replies 15
spremkumar
Level 9
Level 9
Hi Jay
Are you able to ping any of the outside ips from PIXs inside lan ?
Also what kinda NAT is being configured there in your network?
Also do post your configs (both pix & router) here, so that the same can be verified..
regds
Sorry I'm late replying...
Yes, I'm able to ping. I've changed my configuration; now I have my 2610 as my only router at the moment; I figure if I can just get that to connect to the internet, I can work my way back on everything else. So, my goal is to make a simple internet connection with just my 2610 for the moment. Unfortunately, I still can't connect. Here's my config:
Building configuration...
Current configuration : 1162 bytes
version 12.3
hostname London1
boot-start-marker
boot-end-marker
no logging console
enable secret xxxxxxxxxxxxxxxxxxxxxxxxx
enable password xxxxxxxx
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip dhcp excluded-address 172.16.31.1
ip dhcp excluded-address 172.16.31.2 172.16.31.99
ip dhcp excluded-address 172.16.31.102 172.16.31.254
ip dhcp pool Guardtower
import all
network 172.16.0.0 255.255.255.0
default-router 172.16.31.1
interface Ethernet0/0
description "The Great Outdoors (WAN)"
ip address dhcp
ip access-group 10 out
ip nat outside
full-duplex
no cdp enable
interface Ethernet1/0
description "Private LAN"
ip address 172.16.31.1 255.255.255.0
ip access-group 10 in
ip nat inside
full-duplex
no cdp enable
ip nat inside source list 11 interface Ethernet0/0 overload
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0/0
access-list 10 permit any
access-list 11 permit any
no cdp run
line con 0
line aux 0
line vty 0 4
password xxxxxxxxxxxxxxx
login
end
Any ideas where I'm going wrong?
Jay
Hi Jay
Can you also post your pix config ?
regds
I've taken my PIX offline until further notice. Once I can get my 2610 routing, then I'll probably re-install my pix.
Thanks for responding, by the way...
Jay
hi,
instead of doing
do this
access-list 101 permit ip 172.16.0.0 0.0.255.255 any
if 172.16.0.0 is the first 2 octet of your network if not then add to the access-list the network that you want to allow to hit internet
If at all possible, if "anyone" sees why this isn't working, could you "put it in the proper context" so that it does work? At this point, I figure it's best if someone who "knows" what's wrong makes it a working config (if you don't mind) and I can then trace back the steps it took to get it working.
I'm on a home 8mb/488kbps ADSL connection by the way...
Jay
Hi Jay,
I am not sure whether I follow your ideas but I can see discrepancy in subnetting.
I understand that your clients are on e0/0 which is subnetted to C-class address (/24).
When your router serves as dhcp server you either intend to provide 172.16.31.X address range (but due to "excluded" commands you can only assign 172.16.31.100-101 addresses), in this case your network statement under "ip dhcp pool Guardtower" should read: "network 172.16.31.0 255.555.255.0" NOT "network 172.16.0.0 255.255.255.0" or you intend to provide class B address range in which case your network statement should read "network 172.16.0.0 255.255.0.0". But then you MAY face problems with routing as you specify your default router as e0/0 interface. Also I have no information what sort of address you get assigned from your ISP when your box acts as a dhcp client.
So if you do not mind can you please change your "network (dhcp)" command and see if there is any progress.
Best regards,
Antonin
Okay,
I've scaled it down to just the commands I "think" I need to get my 2610 to connect to the internet and it "still" isn't working:
Current configuration : 1018 bytes
! Last configuration change at 21:26:43 UTC Mon Nov 6 2006
! NVRAM config last updated at 21:26:46 UTC Mon Nov 6 2006
version 12.3
hostname London1
boot-start-marker
boot-end-marker
no logging console
enable secret xxx
enable password xxxxxxxxxxxxxxxx
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip address 87.xxx.xxx.54 255.255.255.0 (WAN IP)
ip nat outside
full-duplex
no cdp enable
ip nat inside
full-duplex
no cdp enable
ip default-gateway 87.xxx.xxx.54
ip http server
ip classless
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
I'm out of ideas...
Jay
Hi Jay
I have 2 suggestions to make here.
1.As already mentioned by the other poster do change the access list entry accordingly to allow only your local lan subnet.
2.Do remove the ip default-gateway command and also the default route pointing via ethernet0/0.
You need to find out the ip address of the gateway equipment from the SP where you are currently getting connected and draft your default route pointing to that ip.
I feel that should solve your problem.
regs
the problem with your number 2 suggestion is the ISP didn't give him a static ip to use for his router, if he was given a static IP that would be fine but since it's via DHCP the default route to the e0/0 int is just fine.
@poster
change the NAT as i have said, i'm pretty sure that's where your problem is
Actally,
if I've never mentioned, I do have a static ip (and about 5 others I'm not using at the moment). I set it to dhcp because I wanted to make sure I was getting out to the internet.
This is pissing me off. I had my pix 501 running inside of 15 minutes so I don't know why it's so friggin' difficult with this piddly 2610?!?!?!? All I want is a simple basic config and I'm into three+ days with this thing :)
Jay
so, did you change the NAT statement?
Yep, and then some and it still didn't work:
version 12.3
hostname London1
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$YxtK$2CA0c/57PnC/6tOsyMwDu0
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip dhcp pool guardtower
dns-server 87.xxx.xxx.30 87.xxx.xxx.28
ip address dhcp
ip nat outside
full-duplex
no cdp enable
ip nat inside
full-duplex
no cdp enable
router rip
network 172.16.0.0
ip default-gateway 87.xxx.xxx.7
ip nat inside source list 101 interface Ethernet0/0 overload
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 87.xxx.xxx.7
no cdp run
line con 0
line aux 0
line vty 0 4
password xxxxxx
login
end
I tried adding the "dns-server" command and that didn't help either...
Jay
did the isp give you a deafult gateway to use? change your default route to "ip route 0.0.0.0 0.0.0.0 E0/0" and try again. do sh int and get the ip address assigned to e0/0 by the dhcp and do an extended ping to 4.2.2.2 and use the dhcp ip as source and tell us if it's ok or not
