Routing issue 871
jseneca64
Community Member
I am trying to host a wbesite on a Linux server that sits behind an 871w router. When I try to telnet to the public ip port 80 I get "Could not open connection to the host on port 80" Do I need to add a NAT route or modify the ACL? My config is attached.
Thank you,
John
trippi
Level 5
Level 5
You will need a NAT statement, what's your public and private IP for your Linux server? You can post a fake public.
jseneca64
Community Member
Public (fake) 73.183.224.30
linux server: 10.0.1.99
Thanks for your reply...
You have a ACL also applied on the fasteth interface.
regards,
pravin
Static NAT rule.
static (inside,outside) 73.183.224.30 10.0.1.99 netmask 255.255.255.255
ACL (not sure if needed, since you already have internal ACL)
permit tcp any host 73.183.224.30 eq www
