Routing Issue Between VM and CISCO L3 SWITCH
Rags2
Deepak Kumar
Check your virtual switch configuration and firewalls on each host.
Also, make sure you have configured the correct VLANs and corrected VLAN mapping to each port.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
kabirkhaliq772
Kindly check the configuration. As we were facing the same issue for the account of emirates premier league t20. So I explore everything. And was not checking the configuration. After spending 3 days I contacted to one of my friend who is expert in such technical things. SO he told me to check switch configuration. When I check so the issue was with the configuration and after fixing that the whole issue got fixed.
