Routing issue between VRFs
cbabcock05068
I've got an issue I just can't seem to get my head around.  I've a single router with multiple VRFs.  I'm trying to leak a route to allow VRFs to reach a syslog server on the NETMON vrf from AFS:V101 vrf.  It shows that the imports have worked via BGP and route tables look perfect.  I can ping the Gig2 interface that is assigned to the NETMON vrf via a leaked route, but packets dont seem to want to leave the Gi2 interface.  I triple checked the RT and did a packet capture on the server(Win2012). No packets reach the server interface when initiating pings from PE or CE router in vrf AFS:V101, and the frames are going to the correct MAC when I initiate pings from the server.  Very sure I'm missing something in the router.  Any help would be greatly appreciated.  Thanks!!
172-30-3-13-PE1#ping vrf AFS:V101 172.30.13.100      <----[IP address of Gi2 in vrf NETMON.  Leaking seems to be working.]
Sending 5, 100-byte ICMP Echos to 172.30.13.100, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/13 ms
172-30-3-13-PE1#ping vrf NETMON 172.30.13.28      <----[The host is alive. ]
Sending 5, 100-byte ICMP Echos to 172.30.13.28, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/9/18 ms
172-30-3-13-PE1#ping vrf AFS:V101 172.30.13.28     <----[Packets do not leave the interface of Gi2.]
Success rate is 0 percent (0/5)
172-30-3-13-PE1#
VRFs:
vrf definition AFS:V101
 rd 100:101
 route-target export 100:1
 route-target import 100:1
 route-target import 100:101
 address-family ipv4
  route-target export 100:101
 exit-address-family
vrf definition NETMON
 rd 100:1
 address-family ipv4
 exit-address-family
interface GigabitEthernet2
 vrf forwarding NETMON
 ip address 172.30.13.100 255.255.255.0
 negotiation auto
end
interface Loopback100
 vrf forwarding AFS:V101
 ip address 10.14.1.1 255.255.255.255
 ip mtu 1450
end
[VRF NETMON route table]
172-30-3-13-PE1#sho ip ro vrf NETMON | b Gateway
Gateway of last resort is not set
      10.0.0.0/32 is subnetted, 2 subnets
B        10.14.1.1 is directly connected, 01:47:39, Loopback100
B        10.114.1.101 is directly connected, 01:19:12, Virtual-Access2.1
      172.30.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.30.13.0/24 is directly connected, GigabitEthernet2
L        172.30.13.100/32 is directly connected, GigabitEthernet2
172-30-3-13-PE1#sho ip ro vrf AFS:V101 | b Gateway
      10.0.0.0/32 is subnetted, 3 subnets
C        10.14.1.1 is directly connected, Loopback100
C        10.114.1.101 is directly connected, Virtual-Access2.1
B        10.214.1.103 [200/0] via 10.114.1.101, 01:18:30
B        172.30.13.0/24 is directly connected, 01:47:57, GigabitEthernet2
172-30-3-13-PE1#
172-30-3-13-PE1#sho ip bgp vpnv4 all
     Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 100:1 (default for vrf NETMON)
 *>  10.14.1.1/32     0.0.0.0              10000         32768 ?
 *>  10.114.1.101/32  0.0.0.0              10000         32768 ?
 *>  172.30.13.0/24   0.0.0.0              20000         32768 ?
Route Distinguisher: 100:101 (default for vrf AFS:V101)
 *>i 10.214.1.103/32  10.114.1.101                  100      0 i
 * i                  10.114.1.101                           0 i
172-30-3-13-PE1#
0 Replies 0
