Routing issue from another subnet
RAJA RAHMAN
HI All
From our site B we are not able to reach VPN  user
setup is like
VPN  user( 192.168.100.0)-------SITE A nerwork (192.168.10.0)----------  SITE B ( 192.168.30.0)
The MPLS is working through OSPF we have did route map for some subnets
From Site B if we try to do trace route it is getting failed  after it reaches the siteA wan
Site A MPLS wan  192.168.15.1
Site B MPLS WAN 192.168.17.1
I here attached the configuration and network diagram  and the configuration of the router and switches
Please help us to resolve the issue
regards
RR
kcnajaf
Level 7
Level 7
Hi Raja,
On your site A MPLS switch i can see the static route as below.
ip route 192.168.100.0 255.255.255.0 192.168.10.251
The next hope which is showing here is 192.168.10.251 (Not sure if this should be pointing to switch 192.168.10.254) which accroding to your diagram is Sonic Firewall. Firewall more likely wouldn't be allowing traceroute and hence that may be the reason your saying trace result as your seeing now.
How is the routing and firewall policy looking on the firewall? From firewall are you able to reach 192.168.100.x and 192.168.30.x network
Najaf
Please rate when applicable or helpful !!!
