Routing Issues
Mikey John
Level 4
Level 4
Not sure If i should be posting my query out here as it is a very basic one.
Iam using GNS3 simulator to connect the devices as shown in the diag attached. Iam using a Router on a stick configuration between R1 (3620) and R2(Cisco 3725 with Ether switch module).
On R1, I have created 2 sub-interfaces 200 and 300 on Fa0/0 towards R2.
interface FastEthernet0/0.200
encapsulation dot1Q 200
ip address 10.1.1.1 / 24
interface FastEthernet0/0.300
encapsulation dot1Q 300
ip address 11.1.1.1 / 24
On R2 switch, Fa1/1 connecting to R1 is a trunk port and Fa1/2 connecting to R3 is also a trunk port.
interface FastEthernet1/1 --->towards R1
switchport mode trunk
duplex full
speed 100
interface FastEthernet1/2 ---> towards R2
duplex full
speed 100
interface Vlan200
ip address 10.1.1.10 255.255.255.0
no ip route-cache
ip route 0.0.0.0 0.0.0.0 10.1.1.1
On R3 router, Fa0/0 interface towards R2 is configured
ip address 11.1.1.5 255.255.255.0
duplex auto
speed auto
From R3, I need to reach the 11.1.1.1 IP address of R1, but Iam unable to ping, What should be the static route on R3 to reach R1? Do I have to make R2 a L3 switch?
Appreciate your help.
Mikey
7 Replies 7
Mikey John
Level 4
Level 4
Any help on this would be appreciated.
Mikey
you don't need any static route on R3 to reach 11.1.1.1 as this IP address is on the same subnet.
If you are using a RoAS design then R2 should be a L2 switch only so disable ip routing on R2.
on R3 you must also be in the same VLAN as R1 f0/0.300 subinterface as you are in the same subnet so just make f1/2on R2 an access port in VLAN 300. For R3 to ping f0/0.200 then use a static route on R3 pointing towards R1 f0/0.300 IP address.
Alain
Thanks. Also, would have a 2nd uplink between R3 and R2 make sense? R2 being a L2 switch would block the link anyways. Right?
yes,you're correct that STP on R2 would block one of these links.But you also couldn't have the second link on R3 in the same subnet(every interface on a router must be in its own subnet) so unless you were doing a L3 port-channel between R2 and R3 which you won't as R2 is now a L2 switch then this  second link will have no purpose.
Alain
So if I have a /24 subnet to be used between R1 and R3, I can further divide that and use as 2x/29 for both the uplinks.
The 2nd blocked uplink could act as a standby in case fa0/0 on R3 goes down.
But is it worth doing this? What would be the best practice?
Mikey
in that case you would have 2 subnets on R3 and from a /24 you can get 2 /25s but if R2 is still a L2 switch it means you either have 2 access links going to R3 each in a different VLAN and going to each routed interface on R3 which are in different subnets or you use a trunk on R2 for these 2 VLANs and on R3 you have 2 subinterfaces each in a different subnet and VLAN.if you have 2 access links in 2 VLANs then there won't be no blocking( I answered incorrectly about this in my latest reply) as they are on 2 different STP instances.
You'll also need the same /25s on a subinterface on R1 for intervlan routing.
Alain
Thanks Cadet. Pretty helpful.
